Old 08-06-2006, 04:23 PM   #19
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
hey thats a pretty cool idea actually. This wiring took a while to do... so i'm keepin it the way it is. It would also take a lot of wire and me taking apart the headliner.
MacMaster761 is offline   Reply With Quote
Old 08-06-2006, 07:56 PM   #20
Kr0n1k
Drives: AE101 Prizm('07 Yaris 3DR TBA)
If you wanted to do it, you could probably get to the switch on the door jam.
Kr0n1k is offline   Reply With Quote
Old 08-06-2006, 08:48 PM   #21
twixt
Drives: 07 LB,04&06 ninja 636
Send a message via AIM to twixt
there is a domelight wire under the dash to wire to the door switch would require a relay, and the domelight wire should be tested with a multimeter before you start splicing, im not sure if its 12v
twixt is offline   Reply With Quote
Old 08-06-2006, 08:52 PM   #22
ChinoCharles
Drives: LB
Nice twixt
Old 08-06-2006, 09:27 PM   #23
Kr0n1k
I may try my own idea when I get my Yaris (in October ) thanks Twixit.
Old 08-06-2006, 10:10 PM   #24
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
should be ~12v., that's what the dome bulb is rated for, definately use a relay, you don't want to power the cathode transformer off the dome light's wire, that would probably draw too much current.
paultyler_82 is offline   Reply With Quote
Old 08-06-2006, 10:13 PM   #25
paultyler_82
This is what I'll be doing as well, using my own design of LED tube instead of cathodes, let me know if you need any help with the wiring or anything.
Old 08-06-2006, 11:13 PM   #26
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I mounted my tubes to the silver cross brace under the seat with 3M tape the underdash tubes as well, more of a floor glow than anything else. I like somewhat dimmer lighting - is it actually as bright as the photos show?
mikeukrainetz is offline   Reply With Quote
Old 08-06-2006, 11:57 PM   #27
Kr0n1k
Thanks Paul, will do. I'm gonna have a stack of parts and a long list of mods by the time I actually get the damn car.
Old 08-07-2006, 07:50 AM   #28
MacMaster761
Five-Star General
its brighter than the photos show, i had to reduce the shutter speed so it wouldnt blur as much on the camera. I'll hook it up to a tripod tonight and take a real photo. I dont even wanna touch that relay stuff, that looks a little complicated.
Old 08-07-2006, 10:56 PM   #29
captainzerocool
CAMRY FTW!
captainzerocool's Avatar
Drives: Camry LE V-6 (225,000+ miles)
Nice mod.
I drive a Camry.
I have no imagination.
captainzerocool is offline   Reply With Quote
Old 12-03-2006, 03:59 PM   #30
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
what did you use for power and did you have to buy a switch or did it come with
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 12-03-2006, 05:06 PM   #31
ChinoCharles
Drives: LB
It really looks perfect. What I want to know is if there is way to wire them to the stock dome light so they will fade on when the door is opened, and concurrently wire them to a switch so you can turn them on if you're driving around and want to have them on to show off a bit... without of course having that switch also turn the dome light on. Sounds complicated.
Old 12-03-2006, 08:35 PM   #32
spkrman
Drives: 1
oznium 'thodes are the shyte... not the most durable, but they are really bright and cheap!
Old 12-04-2006, 06:36 PM   #33
Notthy[Yaris/S]07
Notthy[Yaris/S]07's Avatar
Drives: Yaris Sedan 07
looks great
My Ride From Puerto Rico Yaris Sedan 07
- MODS -
20% Tints
Tanabe NF2210 Suspension
Two AudioPipe 12 Inches for Bass with 1000 Watts Amp BOSS
17 Inches Rims
Ground Wire
Notthy[Yaris/S]07 is offline   Reply With Quote
Old 12-05-2006, 11:24 PM   #34
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
looks good
nick1983 is offline   Reply With Quote
Old 12-06-2006, 12:20 AM   #35
ChinoCharles
Drives: LB
Ordered a kit today in blue.
Old 12-06-2006, 07:26 AM   #36
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
What kit?
I picked-up a dual cold cath kit from compusa for just under $20. The kit came with a switch, but I swapped it for a lighted one from AutoZone.
I wish I had taken some pics of my install, it would be a crazy easy DIY write up, unless it involded hooking into the Dome Light wire and still having it "switchable"; if only i knew more about using relays....
will work for parts
vodkalush is offline   Reply With Quote
Toyota Australia releases YRX SEDAN. Sp33dY General Yaris / Vitz Discussion 1 08-01-2006 01:19 AM
Looking for Yaris Sedan modifications! PMCRW New YARIS Purchase Forum 1 06-15-2006 12:51 AM
