#19 | |
Who said Yaris was slow?
This is what I did with very good results: I removed only the secondary cat (our car has 2 cats) and left the primary cat alone, that way the car will pass emmissions test. Then I removed all the exhaust from the primary cat back and replace it by a custom unit. I used 2.25" pipe, a resonator and a rear chambered muffler. Sounds great and I felt some good gains on the top range mostly. |
#20 |
![]() Drives: 1,5 turbo yaris 2005mod Join Date: Sep 2009
#21 | |
The boost will not go up. The boost level is controlled by the internal wastegate spring on the turbo. 2 main benefits you will get from the free flowing exhaust... Better turbo spool up ( reaction time ) and you will pick up a few HP's mostly on the higher Revs... |
#22 |
today i recived my car back from the work shop, so now i have a brand new engine, whats the best way to brake in the engine? when can i use the full engine power? any tips? :)
#23 | |
If you raise the boost to 0.65bar the car will definitely lean out and you will be on risk again. You need to understand that the ECU in your car was programmed by TRD to run very low boost... You can raise your boost as long as you have some way to properly tune your fuel and timing. You will need a programmable ECU or piggy back to do that, such as a Greddy emanage or SAFC, AEM FIC. Another option that you have in order to raise the boost to 0.65 safely, is using a water/ meth injection system. Usually a water meth set up will suppress the knock an will allow you to raise your boost level with no further tuning. |
#24 |
I don't know what to tell you as I have no idea what you mean by chip tuned.
In an earlier post you mentioned that the chip only raised the rev limit. Does the chip also controls fuel and timing? What where you A/F readings when you were boosting 1bar? I can't imagine how your injectors were able to provide enough fuel at that boost level... The best advise that I can give you... if you want to make the most out of your car with out braking it again is to take it to a reputable tuner to install a REAL programmable computer. Only doing that you will be able to control all the critical parameters. SI not only about fuel... You need to take out ignition timing... this is a high compression engine... you have to relay on a very good tune if you are increasing the boost. In simple words... it will be expensive to safely increase the boost... |
#25 |
When you aare running higher boost than stock you have to be very careful. A correct MAP for your set up is the key. I don't know if the car will go lean just becasue of the exhaust but i would suggest not to take your chances.
Get the exhaust done and then get the car remaped properly. You will feel better dirving your car afterwards. The problem with the open blow off valve is that in some occasions the car will go too rich and stall... mostly because you are releasing air that was already measured by your MAF. This is usually not much of a problem... i know of 2 yaris running with vented BOV's with no problem. At stock boost level the car doesn't really NEED one (hence why TRD didn't added one) but for the sake of your turbo, if you are raising the boost it is definetely a good idea to instal one BOV. You can always recirculate the BOV, like most of the OE turbo cars... you can use a regular Bosch valve from a VW/Audi and have the air recirculated back to the intake. That way the car won't stall and you will be protecting your turbo... |
#26 | |
I know of 2 Yaris here running catless and 2.25 and 2.5 exhausts with the stock map with no problem. The spool up will improve... but is not that much!! These cars are lagless from the box. So I would not be worried about that. And the BOV should not be a problem either.. |
#27 | |
![]() ![]() i think that i will build the exhaust and put on the bov, and leave the stock boost att 0,5 bar, because then the car woul last longer i think:):) the new engine wouks good so far:) |
#28 |
hello castrex, i got one question for you if you know, the do you know if the first muffler after the turbo is an catlysator? or just an filter ?
i im just wondering if there is any help to remove it. |
#29 | |
If you don't need to take the gar for inspection you can remove it. It's usually ilegal in many places. Not sure in your country. You can probbaly gain a couple extra HP taking the cat out. You can also replace it with a high flow race cat. |
#30 |
okey, i was thinking off removing the cat number two att first,:) i did install an aem wideband yesturday, and att full throttle att 3-4 gear the messure was 10,0 att 4500-6200rpm the aem doesent messure lower:/ so i think i have enought fuel, , i have stock boost and stock exhaust now.
#31 |
yesturday i did messure my wideband..the results: started att 1500rpm on 5gear messurements: 1700rpm 13,0....1900rpm 13,3....2300rpm 13,4....2500rpm 13,7...... 2700rpm 13,9..... 2800rpm.14,0....3000rpm-13,5...3200rpm 12,0... 3500rpm 11.8.... 3800rpm-10.7...4000-6200 rpm 10,0
castrex : what do think? this messure are with stock boost. i think maybe it a bit lean att 2800 rpm? what would hapen if i bouild exhaust? im going to do an new messure today and see if i do get the same |
#32 | |
These numbers don't tell much unless you can add the boost figures also. It does a bit lean at 2800 as you said if you are indeed boosting at that RPMS. It does also look quite rich at the top end... if you could lean that out you will gain some power up top. How many psi are you seeing at 2500/2800 rpm? Overall it doesn't look bad. You have enough fuel obviously. Some fine tuning would help. Why don't you try getting a SAFC or a greddy emange? You should be fine if you build a full exhaust. |
#33 | |
i got 0,5 bar boost at 1700 rpm and i have the same boost att 6200 rpm.. the car is now totaly stock.. so you think that it wouldnt be a problem to bouild exhaust now?:) |
#34 | |
OK so you are hitting full boost at 1,700rpm so it seems like you are running a bit lean from 1,700rpm to above 3,200rpm I would still think about some sort of management like a emanage, SAFC, AEM FIC so you can load a smother curve. But overll you seem to be fine. TRD knows what they are doing... and as long as you don't raise the boost, an aftermarket exhaust should not be a problem. |
#35 | |
http://www.greddy.com/products/displ...SubCategory=47 it seems like they have kit also for my car? is it difficult to program this? |
#36 | |
Yep they do. Is not difficult if you know what you are doing... If you understand the basics of engine tuning and are willing to take some risks you can do it your self. My advise, look for a local Emanage tuner. This is a very popular device, finding a tuner for it shouldn't be that difficult. |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
