Old 11-05-2009, 08:41 PM   #1
regal
Drives: 09 Yaris 3 Dr White LB
Actron CP9135 Scanner
I bought an Actron CP9135 OBDII scanner at the pawn shop because it was recommended to me as being a good one to use on my 97 Crown Vic that I am fixing up.
It got me wondering if it would work with the 2009 Yaris, of course I have never had any issues with this cew car but if the CEL comes on it would be nice to have a compatible scanner.
Do we think the Actron CP9135 OBDII scanner would work with an 09 Yaris or has the ports/standards changed since 97 ?
regal is offline   Reply With Quote
Old 11-05-2009, 08:49 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Any obd2 scanner will work on any obd2 car. All cars are ob2 that are 96 or newer.
Old 11-05-2009, 09:21 PM   #3
regal
Thanks , are the codes standard with a list somewhere or do you need the factory service manual?
Old 11-05-2009, 09:50 PM   #4
Actually, I don't think the CP9135 will work with the Yaris. I don't believe that it supports CAN bus communication. Older code scanners only supported ISO-9141 .
The Yaris supports the OBDII data protocol, but over CAN bus, no ISO-9141.
Old 11-06-2009, 08:16 AM   #5
regal
Is there an adapter to allow it to connect to canbus or am I SOL? Guess I should have asked you guys for a recommended scanner first.
Old 11-06-2009, 12:23 PM   #6
I would check with Actron to see if there is an upgrade for it. I looked at the online manual for it last night and there was no mention of CAN support.
Old 11-09-2009, 12:29 AM   #7
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
A few years ago, Actron used to sell upgrade kits to install in their scanners so as to make them work with CAN-bus. I upgraded my 9145 that way. Those older models are no longer sold, so it's unlikely they still sell the kits. But it doesn't cost anything to call them and ask!
Reddog99 is offline   Reply With Quote
Got a Scanner finally as well... at3GG Photo-Video-Media Gallery 8 04-15-2009 05:04 PM
