I got another CEL :(
Installed the nitto midpipe about 4 months ago and got a CEL. Installed the o2 anti fouler and it got rid of it for about 3 months. Acouple days ago it turned back on
Anyone else with the Nitto MP have this problem?
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
get a o2 simulator. if you can't find one i can find you one on the camaro forums.
fill the hole, with a plug, use antiseize. and dont worry about the after cat sensor any more. now if you're talking for the pre-cat sensor...i dont know what to tell you other than to try a new sensor. |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
I have the Nitto Mid Pipe with the O2 Anti-Fouler, No CEL for me. I had a problem with the O2 sensor bung, but it was a simple re-weld job. I've had my mid pipe on since June. Do you know what code it's throwing?
check the code.
I think I may hear a slight exhaust leak. Is it possible for that to throw a code
I didn't use any washers in between the fittings because there weren't any from the factory. Are you guys using crush washers on your fittings?
shoulda checked the code.
Have no way of checking it. No scangauge and the local checker guy is a douche that won't let customers use the code reader anymore
Anyway I tightened up the gas cap and it is still on. Do I NEED to clear the code or should it go away after a little while
It even says it on the gas cap. I think the light should go off if you've re-tightened the gas cap and drive around a little bit. That's what happened to my friends IS250 and the light shut off. If not have someone check the code before you get reset just to make sureLast edited by hatchbackkid82; 11-12-2009 at 12:57 PM. |
#11 | |
| Afe intake installed...CEL ??? | vten | Performance Modifications | 7 | 06-05-2009 12:08 AM |
| going from 91 to 87 gave me CEL! FLAME ON | enviri | General Yaris / Vitz Discussion | 28 | 05-24-2009 09:42 AM |
| CEL Issue via MAF Sensor, Thoughts? | The Architect | Performance Modifications | 8 | 03-29-2009 11:50 PM |
| FS: Sedan Nitto Mid-Pipe w/ CEL Fix | Split | Items for Sale by private party | 37 | 12-18-2008 12:11 PM |
| Non cat exhaust CEL? | CASTREX | Performance Modifications | 15 | 01-28-2007 01:22 PM |
