#37 |
I love momentum.
I have some AMSOIL 75w90 SVG gear oil on the way. Looking forward to putting it in.
Edit: Despite that fact that AMSOIL's site (and a technical rep I emailed) said that the SVG will work in both GL-4 and GL-5 boxes, and is fine for my Yaris, I'm still nervous using it. I may see if I can swap it for the straight GL-4 AMSOIL fluid. Thoughts anyone? Last edited by schleppy; 10-17-2009 at 04:38 PM. |
#38 |
![]() ![]() Drives: Yaris Sol 1.3 dual VVTi 101hp Join Date: Apr 2009
I made a mix (about 80:20) between RedLine MT-90 & MTL, the gearbox definitively feels better & changing gear also on high rpms isn't a problem any more even if I noticed that on heavy load, for example when I push the car very hard for 20/30 minutes, it's noticeable the "slippering" effect... so I was thinking to flush & change again but this time going to test Amsoil GL4 75w90
I think that the severe gear grade is too strong for our transmission, I think I'll stay with standard GL4 Amsoil grade... GMT or GTM right now I don't remember the exact name what is your opinion on usgin Amsoil GL4 instead of the Severe grade??
Yaris Sol 1.33 dual VVTi model 09 - 5dr 1. full ZX1 additive treatment: oil + cooler + fuel 2. NB treatment: motor oil 3. K&N panel air filter (part num. 33-2211) 4. Fuchs Silkolene Pro SRG 75 gear oil (the best!) 5. UltraRacing 19mm rear sway bar |
#39 |
![]() ![]() ![]() Drives: Blazing Blue 08 liftback Join Date: Dec 2008
I'll be using Amsoil SVG 75w90 as I'm due to drain the factory stuff. I think GL 5 is recommended in my owners manual, 08 yaris, so that's what I got. Plus AX works the car a bit harder sometimes.
I hope you'll consider Trulube.com as your Amsoil dealer.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com Last edited by Lazerdot; 11-17-2009 at 06:51 AM. |
#40 | |
GL5 has sulpher which will dammage transmissions speced for GL4. (makes sulpheric acid) GL4 trannys have copper etc whcih will be destroyed by GL5 stuff. Your trials are meaningless since real tests of lubricants last for hundreds of thousands (if not millions) of miles. |
#41 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
agree , stay away from GL-5 . Used MOBIL synthetic GL-5 in a COROLLA that made shifting difficult ( grinding ) and going into reverse a chore ( clunking ) . Stick with a GL- 4 , much better results .
#42 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
Been there and tried GL-5 too in my transmission by mistake, had to drain it out-total waist of $16 of mobile one gear oil. Ended up going with Redline MT-90 which is GL-4 and recommended for Toyota gear boxes. Just stick with any GL-4
#43 | |
![]() it's almost impossible to find amsoil products outside US, for me it would OK also getting from UK, De, Fr, Ir... every other nation in europe
#44 |
I'd love to get over your way for a vacation!
Sorry About the shipping issue. Have fun with car!
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com |
#45 |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
MT-90 is the best stuff at the best price....
#46 |
If ordered direct from me at Greg@TruLube.com I can ship stuff but not sure the cost or best shipper. I use paypal so that end is covered. Just and option for you guys overseas.
Checkout TruLube.com to decide what you need and let me know by the e-mail included. Greg
#47 |
damn... if I think that 10 days ago I was in NY...
#48 |
so the Amsoil 75w90 SVG even if specified as both GL4/5 by the dealer can't be used in a GL4 spec gearbox?? a bit confused...
#49 |
Since I AX and do track days and since my 08 recommends both, I'm using Amsoil SVG 75w-90.
#50 |
so your manual says "GL4 or GL5" ?? very strange... they are almost incompatible each other
#51 |
Yup, confusing but still recommend. My understanding when looking at the SVG 75w-90 is it should be used under harser conditions. Otherwise I would have used the Amsoil GL4.
available
| Look what just came in the mail today!! | PETERPOOP | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 48 | 10-21-2008 09:34 PM |
| Where is my oil leak coming from? The Gearbox? | MarkBond | General Yaris / Vitz Discussion | 1 | 08-25-2007 10:31 PM |
| Finally ordered my new rims today! Thanks for all the help | thomasward00 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 06-03-2007 06:37 PM |
| Got my second door ding today! | bugnuts | General Yaris / Vitz Discussion | 5 | 03-14-2007 10:07 AM |
| Placed my order today | drdavidr4u | New YARIS Purchase Forum | 8 | 06-19-2006 03:43 PM |
