Old 12-15-2006, 03:23 PM   #1
NotAMini
Drives: Dealer Strip Model
15 x 8 with 30 offset.
Will pop out too far?
NotAMini is offline   Reply With Quote
Old 12-15-2006, 04:09 PM   #2
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
loooooow-ridah!
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline   Reply With Quote
Old 12-15-2006, 04:25 PM   #3
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
do you have lowering springs ?
what wheels are those, pics ?
hystria is offline   Reply With Quote
Old 12-15-2006, 06:28 PM   #4
NotAMini
I was thinking about th Rota RB. Will drop in about 1.5 or so.
Old 12-15-2006, 07:50 PM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
I have 15x7 +38 with 225-50's and mine stick out a smidge
so an inch wider with a lower offset should be sticking out a lil over an inch, so as stated before...loooooow-ridah!
Old 12-16-2006, 12:43 AM   #6
03Z33
03Z33's Avatar
Drives: TCR10
They'll actually fit almost perfectly flush all around with some 195/50/15 tires. You will need to run at least -1.5 deg. camber up front, rear will clear no problem.
I'm running 16x8 +25 up front with 195/45/16 with -2 deg. camber and it tucks in perfect 16x8 +15 rear pokes nice too
Old 12-16-2006, 12:59 AM   #7
static808
static808's Avatar
wow, i took a quick peek at your garage and it does look quite nice. how has the camber change affected your handling and tire wear?? i'd never think that someone could pull off those kinds of wheel numbers with a yaris...
--B
Old 12-16-2006, 01:07 AM   #8
03Z33
03Z33's Avatar
Drives: TCR10
--B
I haven't posted any pics of these wheels yet... I'm waiting for some different coilovers so that I can lower the front more first. Camber won't affect your tire wear too much, it's toe that kills tires. If you drive aggressively and corner a lot like I do, the negative camber will actually help increase tire life. I run -2 deg front and -2 deg rear (shimmed) with 0 toe all around. It makes the car feel 100% better (handles like a go kart!)
For OP, you may want to run 195/55/15 tires if you don't plan to lower the car a lot, this will help fill in the fender gap a bit more, and will be easier to stretch since they have more sidewall.
Old 12-18-2006, 10:51 AM   #9
NotAMini
nice. Thanks for the info.
Old 12-24-2006, 10:34 PM   #10
DTM_Yaris
Turbo Yaris
DTM_Yaris's Avatar
Drives: 07 PW Yaris
Too much - Camber will destroy tires very quickly depending on your driving habits.
BUT you are correct toe will mutilate tires even faster.
DTM_Yaris is offline   Reply With Quote
Old 12-24-2006, 10:37 PM   #11
DTM_Yaris
Turbo Yaris
DTM_Yaris's Avatar
Drives: 07 PW Yaris
Because of the width you will be protruding approx. 47 mm out of your current wheel and tire offset position. Should look pretty good.
My 225's barely tuck. You should be right on that border.
Old 12-25-2006, 10:59 AM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
15X7 +23MM and a 205-55-15 fit nicely..
Old 12-25-2006, 06:49 PM   #13
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
no they don't
Russelt3hPirate is offline   Reply With Quote
Old 12-25-2006, 06:53 PM   #14
03Z33
03Z33's Avatar
Drives: TCR10
Originally Posted by Russelt3hPirate View Post
no they don't
haha... do you know something we don't? I'm sure they fit fine
Old 12-25-2006, 06:55 PM   #15
Russelt3hPirate
l33t3st Asshole
we put those exact wheels Tamago is talking about on my girls yaris and they poked too much for my taste on stock suspension.
maybe with 2.0 negative camber all around and some lowering springs it'd work.
Old 12-25-2006, 07:07 PM   #16
03Z33
03Z33's Avatar
Drives: TCR10
Makes sense
I bet I would still rock them though
Old 02-18-2007, 02:03 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
c'mon, that ain't a poke :)
Old 02-18-2007, 05:30 PM   #18
Russelt3hPirate
l33t3st Asshole
xA :lol:
come on Joel when do we get to throw those bad boys on the yaris? :)
Question about wheel Offset monoculusjoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-07-2006 03:03 AM
Ideal Offset? 15x7 ET42 Wheels TRD_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-18-2006 04:12 AM
15x8 with a 0 offset birdy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-10-2006 05:40 AM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
Max offset riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-01-2006 09:57 PM
