#19 | |
The Beautification of Car
If you do have DRL = Day Time Running Light, you will need to disconnect it someway or somehow, either a fuse, a plug or something. HID don't like DRL My gf got a Aveo, and she got h4 bulb with DRL, so to be able to install HID, i need to remove the DRL plug under her steering wheel to disable DRL, and then when you install HID you will loose DRL. Or as other said you can wire it to highbeam and use your highbeam as HID, but if you don't know then it's will be a mess. |
#20 | |
![]() Drives: yaris, venza Join Date: Nov 2009
so i have to remove the DRL relay in order for the lights to work properly? waiting for an answer for those of you got the bi-xenon or H4 hi/lo kit, that, with those 2 kits, would you still have your DRL? thanks. |
#21 |
you likely still have your drl's active and its friggin up your ballasts when you don't run w/ the low beams actually on
the bixenon kits i sell come with a relay so that you don't need to disconnect your drl module, the hid's just won't fire up when the wattage is too low....PM if you're interested, i have several H4 kits in stock in varying colour temps...
#22 |
![]() ![]() Drives: 09 3dr (sold), 12 SE 5spd : ) Join Date: May 2009
Not trying to jack this thread, but sounds like you should get another kit with both high and low, not just low. Cut your losses and frustration and buy a good set of HID's
What is the best and most cost effective HID kit for the Yaris? I am very interested in getting some.
Its all about the MPG's !! |
#23 | |
![]() ![]() ![]() Drives: '07 Yaris Sedan/'03 Protege Join Date: Oct 2008
| XenithXenon HID Conversion Kit | CorSport | CorSport | 0 | 09-03-2009 05:11 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
| KLight HID Conversion Group Buy!! $165.00 shipped!! | JRT lighting | Sponsors Classifieds Area | 4 | 11-20-2006 10:47 PM |
