Old 12-06-2009, 01:21 AM   #1
Mister Z
Drives: 08 Yaris HB
Question Lowest offset
Whats the lowest offset and widest wheel run on a yaris?
Mister Z is offline   Reply With Quote
Old 12-06-2009, 01:28 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You can run whatever you like. Depends on how you want your car to look and/or perform.
You have to be more specific on what kind of look you want.
There is a sticky thread on wheels in this section (above).
by the way... welcome to YW.
Old 12-06-2009, 02:05 AM   #3
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Welcome to YW!
You also have to ask yourself if you plan on suspension mods too. If so which method: lowering springs, struts, or coilovers? Certain ride heights and spring rates can cause rubbing at certain offsets and rim + tire sizes. It just depends on what you're willing to deal with while driving...
Old 12-06-2009, 03:32 PM   #4
Mister Z
Drives: 08 Yaris HB
I'm looking at wheels that are 16x8 +0 offset all around. As far as suspension goes, I was either going with coilovers or the Tein s-techs as this springs give the lowest drop from all the available springs.
Old 12-06-2009, 03:49 PM   #5
supmet
Drives: 2007 4 Door Yaris
There are pics of 15x8 with 20 offset in this thread. Not sure if it helps.. I'd talk to tamago about it, and he could tell you if its doable and/or if you need hub spacers or anything.
http://www.yarisworld.com/forums/sho...highlight=15x8
Also, I think DF210s are lower than tein s.techs
Old 12-06-2009, 06:46 PM   #6
Mister Z
Drives: 08 Yaris HB
From what I have read is that the s-techs drop the car 1.9 inches all around. The DF210s drop 1.8 in the front and 1.6 in the rear. Unless i am mistaken?
Old 12-06-2009, 09:06 PM   #7
toad
toad's Avatar
Drives: street-legal go-kart
actually, it's 1.6 front and 1.8 rear however, many people say the dfs sag a little so maybe the difference is minimal
toad is offline   Reply With Quote
Old 12-11-2009, 01:04 PM   #8
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
if you get coilovers, you'll be fine with that setup
Its a Chao!!!
Old 12-11-2009, 01:47 PM   #9
Brentorius
Drives: 07 Mazda MX5 Copper Red
As long as the ride height is stock!
An 16x8" wheel with 0 offset assuming 205/40 tires will stick out 55mm or 2.2" more than stock steelies/rubber.
Plus the speedometer will read 5.5% faster.
Definitely a no-go with the S-techs!
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 12-11-2009, 05:39 PM   #10
Black Yaris
der Zeck
Black Yaris's Avatar
to tuck a 8 inch wide +0 offset you will have to run a good amount of negative camber and or stretch your tires, or just get a wide body kit..... either way it is just ugly and pointless
Old 12-11-2009, 08:10 PM   #11
coffiend
coffiend's Avatar
Drives: 08 Black LB
^ opinion. Some people like stretch + camber.
Guilty as charged.
Old 12-12-2009, 01:46 AM   #12
Mateo
Drives: Blazing blue 08 LB
^ I agree man... maybe I spent to much time on vwvortex when I had my jetta.
Mateo is offline   Reply With Quote
Old 12-12-2009, 01:49 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
good luck making it fit.
i'm guessing you're looking at XXR wheels. shame
Old 12-12-2009, 08:54 PM   #14
07blackvitz
07 Liftback
07blackvitz's Avatar
Drives: 2007 Yaris liftback black
I have 15x8 XXR 501 wheels on my car i tested 0-offset XXR 513 but they poke way to much you gonna have to add lots of camber and have your fenders rolled and pumped to run 0's with +15s im running 3.5 negative camber front and rear with a stretch tire lowered on Tein coilovers and rolled the fender.
07blackvitz is offline   Reply With Quote
Old 12-13-2009, 12:33 AM   #15
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
How the heck do you get -3.5 camber in the fronts?
Old 12-13-2009, 12:53 AM   #16
Black Yaris
der Zeck
strut modification
Old 12-13-2009, 05:41 PM   #17
07blackvitz
07 Liftback
What i did was get the SPC camber bolt for the top bolt and ran a Toyota camber bolt for the bottom i forgot what the part number is for the thinnest one is but thats how i got 3.5 negative camber for the from and for the rear i made my own shims similar to what Penguin was selling just a thicker washer.
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 10:09 AM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Proper offset? FA7 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-01-2009 08:37 PM
offset... Keymaster Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-01-2007 01:53 AM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
