![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
new noise
07 Yaris hatch..
This has always run perfect and quiet... almost silent at idle.. We just had 5 days of 15-25 below 0 at night... I started it a couple times only for a half hour or so the whole time... I went on a road trip today and have a new noise... When its idle and you rev it a little it kind of winds down like on a slight delay after you let go of the pedal. Like a kind of whine following the engine sound...it makes the sound reving up and down.. it sounds like some cheap cars sound all the time....its not a scream or grind..just a following delay sound with a plastic overtone... I checked and nothing is rubbing.. I dont like this new development...I am used to perfection from the Yaris.... What do you think...???mechanics...?? Last edited by yaris9876; 12-11-2009 at 08:36 PM. Reason: save |
Read that a couple of times, and I still get kinda lost in it. I'm guessing maybe it's the serpentine belt. They can tend to make some noise as they get older, and especially in the deep cold.
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
I feel your pain.... with the cold weather here, my yaris makes a rattle noise when you rev it.....sooo annoying.
-Jen <3 ![]() Quote:
hey... it happened to mine last year... it turns out to be the water pump getting seized up. It would only do it when cold at first... and then as the weather got colder.. it did it more and more...
finally replaced the water pump |
Really, mine does this wierd noise now that its below freezing, if I leve it in drive or reverse and just tap the gas just a bit, even with no brakes applied, it makes a wierd sound like something is really wrong.
Is this covered by warranty? Or how much is it to buy it, and how much work goes into changing it out? |
redo your anti freeze to 75 % concentrate instead of the standard 50%
thanks dudes, I will swap out the fluid to start with... I have 170K on it so...
| Very loud noise from the engine | Stiv | DIY / Maintenance / Service | 27 | 10-27-2009 10:09 AM |
| strange noise before the car stops | dani1983 | DIY / Maintenance / Service | 14 | 08-15-2009 11:56 AM |
| Random tire thumping noise | Tonavi | DIY / Maintenance / Service | 6 | 06-06-2009 02:27 PM |
| Noise from the drums.... | Lafiro | General Yaris / Vitz Discussion | 18 | 05-22-2009 09:49 AM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 04:21 PM |
