![]() Drives: Yaris T3 Join Date: Dec 2009
Fuel Gauge Stoped Working
Hi guys. My fuel gauge stopped working and is stuck at 1/4 way. is there any fuse that controls this or is there something wrong in the tank. pls help thanks.
dont know about your model, but I believe our fuel gauge is controlled directly from the fuel level gauge in the tank.
Half a Bubble Off Plumb
If you've got the digital gauge with the LCD bars as most of us do, it's pretty much got to be a bad sensor in the tank.
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
I've had the tank unit replaced twice now, and it's gone again. DO NOT depend on the tank gauge! Use your trip odo, and you won't be left stranded out there...
When the sender is disconnected (i.e. if the fuse was popped), the bottom bar flashes rapidly, like you are about to run out. The fuel gauge sender is just a rheostat that is monitored by the combination meter. You may want to pull it out and check the sender rheostat for build-up from impurities in the fuel.
When I pulled Crashy's fuel tank off to do some frame welding, I pulled the sender out of the tank to check it out. Here are some pictures of it: Sender - Gauge.jpg Sender - Side Up.jpg Sender - Top.jpg |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
yeah i never trust fuel gauges, the last bar starts blinking, i should have 1.4 or something gallons, then drops to 1.1 or something when fast blinking, but i fill up when it starts blinking, i never break 10gals at pump. the bars drop too fast i guess. better to be safe than sorry and fill up when it blinks tho.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
thanks guys, will get the hubby to check the tank. thanks a lot for the help.
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 326 | 02-15-2025 11:09 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 04:07 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 03:35 PM |
