Old 12-18-2009, 12:15 AM   #1
Itsnhi
Drives: 2007 Toyota Yaris Sedan Red
Weird Clicking Sounds
Hi,
I bought my 2007 Toyota Yaris sedan this January and sometimes it has this weird subtle clicking noise almost like a small rumble. It's not there all the time. I suspect that it goes off when I'm low on gas, but I'm not sure. Do cars make noise when they're low on gas? I know nothing about cars.
Itsnhi is offline   Reply With Quote
Old 12-18-2009, 12:24 AM   #2
supmet
Drives: 2007 4 Door Yaris
There is no "clicking" sound that is supposed to be there. All alarms on the yaris are chimes, I'm pretty sure.
Check out:
http://www.etimago.com/yaris/TSB/T-S...0Rattle%29.pdf
That's my first guess, 2nd guess is something loose or broken on the air intake.
Old 12-18-2009, 12:25 AM   #3
YAR1S
YAR1S's Avatar
could be the windshield clicking..... thats a known problem too.
-Jen <3
Old 12-18-2009, 04:52 AM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
You need to be more specific. Is it coming from the engine, suspension, body rattle, at idle, on acceleration, while stepping on the brakes, etc... If you keep your tank filled, you might avoid the clicking
Old 12-21-2009, 07:10 PM   #5
taka
Drives: 2008 Sedan
Don't know if this is the same. I had clicking noise from front of car when backing into a parking spot and turning the wheel. Toyota found the mounting bolts were loose between the top of the front strut housing and the cover over the wiper motor.
taka is offline   Reply With Quote
Old 12-22-2009, 11:08 AM   #6
kingstonyaris
Drives: 08 liftback
did you put trim rings on wheels
kingstonyaris is offline   Reply With Quote
Old 12-22-2009, 07:30 PM   #7
woof
Drives: Yaris 3dr Hatch/Black
Sounds like CV joints. They click when they first start to go bad.
woof is offline   Reply With Quote
Weird door locking problem, electrical? davembfan General Yaris / Vitz Discussion 19 09-30-2009 03:50 PM
Weird question, needs some help! hshi DIY / Maintenance / Service 13 01-07-2009 11:54 PM
Weird rattle coming from teh egg. Impresive-G DIY / Maintenance / Service 14 11-10-2008 04:22 AM
this is weird..maybe i should put mine up on ebay hasher22 Australia 1 06-16-2007 10:40 AM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 12:03 PM
