#19 | |
#20 |
I love momentum.
I've had my RS spoiler installed with just 3M tape for months now. Works great! Just make sure the spoiler is clean before you put the tape on, and the parts of the car where the tape is going are clean too. It also helps the tape stick if you heat it up prior to applying, then press it down firmly for 30-60 seconds onto the car.
#21 |
toyota
wow spoiler installed with just 3m tape...really????
#22 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
If you use bolt and nut to put it onyou will need a pyramid bit to cut a big enough hole on back side of hatch to get nut and lock washer in....they are like $50...I use them for work so I have them onhand. A good pilot hole and a good sheet metal screw will hold it on just fine,I did to mine for a week before I took off and retaped and bolted,mainly because I no want it stolen. Take your time,measure many times,have a couple friends hold it and verify it is in right spot,mine ended up 1/8" to the passenger side,not really noticable to anyone but me. |
| DIY Sedan Spoiler Install | Kaotic Lazagna | DIY / Maintenance / Service | 36 | 01-19-2020 11:35 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Yaris RS + Rally Style Spoiler .. possible? | bigsky2 | General Yaris / Vitz Discussion | 41 | 03-07-2014 10:09 PM |
| RS SPOILER ... SAD | aznbabiegrlx0x0 | Cosmetic Modifications (Exterior/Interior) | 42 | 09-28-2007 09:49 PM |
| DIY Sedan Spoiler Install Interest? | Kaotic Lazagna | DIY / Maintenance / Service | 28 | 09-11-2007 11:02 PM |
