Who said Yaris was slow?
How to Disable Trac Control/VSC on the Yaris TS
Info below provided by ANDRIES and I have personally confirmed that it works on 07/08 models.
switch off TRC and VSC Oke, here we go; baseline, engine is off en handbrake is off (downwards) 0. put the key in "contact" 1. clutch downwards 2. handbrake on (up) 3. start engine 4. push twice on the feet brake and by the second time keep it down. 5. handbrake off (down), handbrake on (up),handbrake off (down), handbrake on (up) 6. again push twice on the feet brake and by the second time NOT keep it down. TRC and VSC lights go on. Both systems now off. To put the systems ON simple switch off the engine. When you start again the systems are working normal. I hope I have made a translation in English you understand. Let me know if it was successful to switch it off. Good luck Andries |
aka Jack Wolfskin
TSport Underdog
Castrex, I read you have Smart Entry & Start System on your car, just like mine
How do you do the first step - key in "contact"? Just clutch in and Start the engine? Also, can you tell me where can I find these hidden electronic "secret" programming tidbits? I want my car to auto lock the doors when you start driving (30 kph or so) and unlock when you shut the engine off (I had a 2008 Hilux that had this info on the owners manual and I was successful in programing it - since the local dealer here does not help us much in getting info like you posted) |
On the smart entry system the "key in contact" is just one click on the ignition. So the light on the start turns in orange. No need to push the clutch. is just the equivalent to start the ignition.
It was Andries who found this little trick!! I have no idea where e got it. This is actually intended to put the car in "Dealer Mode" for revisions and such. |
TSport Underdog
I actually went and got it right the first time!
It's kinda funny to do all the steps to get there.... but you DO get there! I took it for a drive around the block (it's raining cats and dogs right now here in PTY) and with the NST pulley and TC off you definitely feel more spirited response (and wheel spin in the wet) Thanks again ![]() TC |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
This works on 2010 Yaris automatic
disable TRAC and VSC ----- within 30 seconds start car footbrake off -------- handbrake ON 2 foot-brakes handbrake off -------- foot-brake ON 2 handbrakes foot-brake off -------- handbrake ON 2 foot-brakes -------------- Trac light will illuminate indicating vsc and trac disabled. will reset next time car is started |
StreetVibeTS
Drives: yaris 1.8 ts Join Date: Sep 2009
hehe it worked perfectly on myne...the car is much different to drive with the VSC turned of, feels more powerful too
Drives: Toyota Yaris T-sport P1 Join Date: May 2009
maybe somebody knows how to turn off VSC and TRC in toyota yaris t-sport 2005 manual, there is switch for TRC, but 'system' of turning off vsc not working, maybe i'm doing something wrong, but following given instructions any ideas?
#9 | |
you hit the switch to disable trac, it will re-enable trac when your speed increases you hit and hold the switch, it will disable both trac and vsc, and that will not re-enable when speed increases that is how it is supposed to work when you have 'the button' |
![]() Drives: Yaris TS 1.5 [NCP13] Join Date: Feb 2010
Hi,
very first post from Italy... I've tried it on my Yaris TS MY03 1.5 just for disable the VSC, for the TRC I've got a specific button but, seems doesn't works.... Anybody knows if there's any other "cheat" that works on my car? Thanks |
![]() ![]() Drives: Yaris TS 1,8L Join Date: Oct 2008
Well guys, I turned of VSC using this method as I did a few times before. Eight of us went to a snow and ice covered empty parking lot and had realy good time :)
In the middle of that 50 minute driving check engine light came on. From that moment on, VSC and check engine became permenanty lit. Today I decided to desconnect battery to reset error code. Now everything works fine. My guess is that this way od disableing VSC is for diagnostic purposes only. The car thought there is an error vith VSC and disabled it permanently. What do you think? |
hmmm, what driving aids usually come with the Yaris? I know ABS was optional....but VSC?
![]() Drives: 2010 Hatch Join Date: Jan 2010
works on 2010's!
#14 | |
![]() Drives: 2000 Yaris 1.0 & 2007 Yaris Ts Join Date: Sep 2009
did you find out how to do the code with the automatic door lock? |
#15 |
TSport Underdog
#16 |
![]() Drives: Yaris TS 05 Join Date: Jun 2011
Bogey i have the same problem of you... we need some help here
#17 |
![]() Drives: Yaris T-Sport Join Date: Jan 2009
Get a piece of wire and short pins 4 and 12 on the obd port briefly just after you start the engine.
This should make alot of lights flash on the dash. Now turn off the engine again without the shorting wire and you should have tc and vsc lights on the dash. To turn it back on Short those two pins before the engine is started and leave it In while you start the car Now pump the brake pedal around 10 times Turn the engine off, remove wire Now it will be reset |
#18 |
thank! just you should make a video demonstrating how to do it since my English is not very good
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
