Old 01-18-2010, 10:24 PM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
LED Side Marker Installation
Hey guys,
I recently purchased a pair of side markers from microimage and need some serious help with installing these guys. I've searched the site high and low for some answers but failed to find anything worth while. My main problem is where I need to wire these in - drilling the holes and extending the wires are no big deal. I'm hoping for a similar plug and play situation found on page 6 of this thread (http://www.yarisworld.com/forums/showthread.php?t=3471), but I'm willing to splice if I must.
Any help would be very, very appreciated. :)
Focus_Sh1ft is offline   Reply With Quote
Old 01-18-2010, 11:45 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Originally Posted by Focus_Sh1ft View Post
Hey guys,
If you got the LED Fender lights from Garm they should be plug and play
if they dont work , unplug the rubber connector and turn it 180degres
Old 01-19-2010, 04:13 AM   #3
Focus_Sh1ft
US models don't appear to have that harness, unfortunately. I even double checked just now. If only it was that simple
Old 01-19-2010, 04:34 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
You got pics please
Old 01-19-2010, 03:50 PM   #5
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
I just installed the kit on my 2007 Yaris Liftback, US model and it went down just like 1NZYaris1 described it...
I was expecting some splicing, but it was a 5 minute plug-and-play job... It was so easy I didn't even bother taking pictures...
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 01-19-2010, 05:33 PM   #6
Focus_Sh1ft
Wow really? It even says on Microimage that splicing will be required. I know you didn't take pictures but can you possibly describe where that harness can be found? I checked on both the driver and passenger's side and don't see anything even close to resembling that. The only place I didn't check was behind the purplish padding along the inside of the fenders...
Old 01-20-2010, 12:37 AM   #7
Focus_Sh1ft
Alright so I was doing some thinking and is it possible the harness is actually in the engine bay? I found a potential harness (found on both the passenger and driver's side) and took a picture of the passenger side.
Could this be it?
Old 01-20-2010, 04:28 PM   #8
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
yeap that looks like it , at the other end is a plug that the Micro Image ones will plug into
uncllip your side markers out of the fender .
and have a look you will be surprised
Old 01-20-2010, 05:54 PM   #9
Focus_Sh1ft
Well I haven't actually drilled the holes yet, and that's why I'm trying to get all this straightened out first. I had a look see again today and I can't see the actual plug, so I'm not 100% sure as to where i need to drill. I tried removing the black plastic in the wheel well but that's wayyyy too huge of a hassle. I guess my next question would be what steps did you guys take to get them totally installed (from start to finish)?
I guess I'm not so confident about drilling the holes afterall
Old 01-20-2010, 06:11 PM   #10
Drilling holes??? Don't need to drill any holes.
1. I just popped off an OEM side marker, I believe you push it towards the back of the car, then out.
2. The harness/plug is right there if you want to try and mate it with the aftermarket one.
3. That didn't work for me, so I snipped it and just wired up the new sidemarker. Took about 5 minutes tops. Test for polarity (reverse the wires if it doesn't light up)
4. Press it into place.
Old 01-20-2010, 06:17 PM   #11
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
From the factory repair manual...
2006 Red Blitzed RS 5-door
Old 01-20-2010, 06:39 PM   #12
Focus_Sh1ft
Alright I'm terribly confused now lmao. I have a sedan, and it doesn't have any OEM side markers nor any potential place to snap part of the area above the fender out to place a side marker. Could it be the sedan wasn't really designed to have a side marker installed, as opposed to the hatchback?
Old 01-20-2010, 06:48 PM   #13
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Oh... hahahha... sorry! My bad I didn't check if you had a sedan..!
Old 01-20-2010, 06:52 PM   #14
Focus_Sh1ft
No worries. I'm beginning to wish I had a hatchback now because it's cake to install compared to the sedan lol.
Old 01-20-2010, 08:24 PM   #15
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
LOL
pays to read your signature
i thought you already had sidemarkers , me bad
if you want i can pop a sidemarker out and trace around the hole
then scan it and then email it to you
Old 01-20-2010, 08:34 PM   #16
DARK AGE 53
Drives: 2009 Yaris Onyx
It's you car but do you really want to make a hole in your fender's like the second pic 1NZYaris1 posted, just my opinon.
DARK AGE 53 is offline   Reply With Quote
Old 01-20-2010, 08:47 PM   #17
Focus_Sh1ft
1NZYaris1, thanks for the offer but nah. There's a good chance I'm just going to wind up cutting away most of the plastic on the back so it's more smooth and apply some 3M double sided adhesive that I have left. Anyways, now I'm back to wondering if I even do have that harness
Old 01-20-2010, 08:53 PM   #18
MadMax
MadMax's Avatar
Don't use double-sided tape, use a sealant such as a silicone waterproof caulk...
JDM Vitz RS Side Mirror with LED Signal Light AlainMikli Cosmetic Modifications (Exterior/Interior) 35 11-18-2013 09:47 AM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 12:48 PM
LED Side Mirror from Micro Image? IsLNdbOi DIY / Maintenance / Service 0 12-21-2009 06:08 AM
side marker lights yrsdrgn Cosmetic Modifications (Exterior/Interior) 154 07-10-2009 03:55 PM
Side Marker Lights Stoln General Yaris / Vitz Discussion 1 07-04-2007 03:44 PM
