Old 01-17-2010, 11:15 PM   #1
Tatsh
Drives: 2009 Toyota Yaris LE
Tires?
Trying to decide what tire size to go with, 205/45/16 or 205/50/16? Anybody got any suggestions or advice?
Tatsh is offline   Reply With Quote
Old 01-18-2010, 07:24 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Are you lowered, and what are the specs on your wheels?
Old 01-18-2010, 11:50 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
205 50 16 is closer to stock height.
Old 01-18-2010, 12:22 PM   #4
Tatsh
Yea, I'm sitting on DF210's. Wheel's are 16x7 +40.
Old 01-18-2010, 03:47 PM   #5
kimona
kimona's Avatar
With that set-up, I'd run 195/50/16's.
Old 01-18-2010, 03:57 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
it's an odd size though. tire rack only shows 11 tires in that size, 42 in 205 50 16.. if you're not picky about WHAT tire you have, go with the skinnier tire i guess..
Old 01-19-2010, 08:21 PM   #7
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
Sorry to hack this thread but I need help about tire size. Is the BFGoodrich Traction T/A Tires 205/55/15 will fit on our stock 185/60/15 tires 15 inch steelies?
Old 01-19-2010, 08:36 PM   #8
I had DF210's with +38mm offset wheels and ran 205/50/16 with no problems. I will say that I had TRD shocks/struts at the time -- stiffer shocks do help prevent rubbing in dips, drops, driveways and bumps.
Old 01-19-2010, 11:51 PM   #9
kimona
kimona's Avatar
It's a bit of a squeeze, but they will fit safely on the stock steel wheels.
Old 01-20-2010, 02:02 AM   #10
Tatsh
I'd go with the 195s to prevent rubbing, too. If you want to go 205, I'd go with the 45-series tires. It also depends on what you're looking for in a tire.
Already found the tire I want, but they came in a few different sizes for 16's, so was just seeing what suggestions you guys had. 205/45/16 was the size I had in mind even before posting the thread. Anyways, thanks!
Old 01-20-2010, 08:04 AM   #11
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
+1. I'm running 205/50's on my stock alloys with no problems
Old 01-20-2010, 09:26 PM   #12
SailDesign
Drives: .
I ran 205/45-16 Toyos on my last Yaris (16x7, +42) with no problems. Loved 'em.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
NEED USED TIRES!!! natethegreat38 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 12-06-2008 12:11 AM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
