Old 01-20-2010, 10:18 AM   #19
teejayy
Drives: Toyota Yaris SR 5dr Hatchback
Picture of UK Toyota Yaris SR with rear foglight on, its nothing special, I hardly ever drive with the rear one on, just the front ones normally. It is useful however if we had a foggy day.
I think the only difference compared to the German Yaris, would be the Foglight would be on the opposite side, considering they drive on the wrong side of the road and all :P
Looks quite white in the photo but I assure you it is red, its just very bright.
teejayy is offline   Reply With Quote
Old 01-20-2010, 07:02 PM   #20
MadMax
MadMax's Avatar
Yep, that's how they worked in my VW; and I figured the same for the Yaris...
Old 04-20-2010, 10:35 PM   #21
Howardt
Drives: 2008 Yaris Sedan
I am planning on moving to the UK shortly and was looking around here in the US for a red bulb to replace one of the rear reverse lights and convert to a rear fog light. I have not been able to find one here and was wondering if you know if they are readily available in the UK. Also, are all UK rear fog lights on the passenger side? Thanks.
Howardt is offline   Reply With Quote
Old 04-21-2010, 05:30 PM   #22
teejayy
The foglight for my yaris is on the Drivers side. Most high end cars have dual rear fog-lights.
I found a link for a replacement fog light bulb which will fit a Toyota Yaris Hatchback, though in the description it said is a white bulb, the lens in the taillight then turns it red. This may be an issue for you? I doubt it would be difficult to source a red bulb from a Toyota Dealership which are in abundance here. http://www.halfords.com/webapp/wcs/s...egoryId_165538
Hope this helps.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 04:09 AM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 04:06 PM
