Old 12-22-2006, 12:45 AM   #1
wushumasterku
Drives: 06 White LE HB 5spd
tanabe or trd
i'm really confused about which ones to get..
i'd like to get 15" rims after lowering my car.
the only reason why i would go for trd is because it would still be under warranty.. but i'm afraid trd would still be too much gap for 15" rims..
can someone advise me?
thanks in advance
wushumasterku is offline   Reply With Quote
Old 12-22-2006, 12:47 AM   #2
ever think about getting the Tein's?
Old 12-22-2006, 12:55 AM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Look for pictures posted of Yari lowered with Tanabe NF210's on stock 15 steel wheels. The NF210's drop the car 1.3 inches, compared to TRD's 1.2 inches. I think the DF210's are to low at 1.6-1.8 inches. If I were you I would go for the TRD's or NF210's, thats what I plan on doing next to my Yaris.
Old 12-22-2006, 12:57 AM   #4
wushumasterku
no, where can i get more info about them? any suppliers on here??
Old 12-22-2006, 12:59 AM   #5
wushumasterku
the DF210's, that's too low for 15 inch rims? i thought it was just perfect, because i saw pics of trd springs with 17 inch rims and it looks ok, so i figure 15 inch rims would still have some wheel gap. is that right?
Old 12-22-2006, 01:01 AM   #6
bigsky2
Cousin Vitz
bigsky2's Avatar
This is what the car will look like after lowering with "TRD" springs (they're rebadged Eibach Sport springs) with 15" alloy wheels:
Old 12-22-2006, 01:05 AM   #7
wushumasterku
thanks bigsky, i was talking about your car in my post above.. i was gonna post a pic of it.. but then you replied here :)
that looks good, but if i was to get lower profile tires, then it could be a problem... or should i leave it around the same profile size as stock tires.. hmmm any suggestions??
Old 12-22-2006, 01:05 AM   #8
wushumasterku
the stock steelies are 14 inch am i correct?
Old 12-22-2006, 01:09 AM   #9
wushumasterku
btw, here's a pic of my car
Old 12-22-2006, 01:09 AM   #10
bigsky2
Cousin Vitz
bigsky2's Avatar
I suggest caculating your overall stock diameter (wheel + tire), and then calculating the new overall diameter with your new wheel and tire setup.
For me, the stock setup was 185-65-R15, and the new setup was 205-40-R17.
I think there is a minor difference in diameter, and hence there is slightly more gap between the tire and my wheel well.
Old 12-22-2006, 01:11 AM   #11
bigsky2
Cousin Vitz
bigsky2's Avatar
I think TRD (Eibach) springs have the least aggressive drop, which is about 1.3~1.5".
The Tanabe offers a more aggressive drop (the DF's I think, correct me if I'm wrong) and a less aggressive drop, NF's. The NF's are comparable to the Eibach/TRDs.
I do not know the drop of the Tein...
If you really want that "tucked" look, with absolutely no gap, I think the Tanabe DF + 15" rims (and proper tires) would look great.
Old 12-22-2006, 01:15 AM   #12
wushumasterku
any rubbing for that set up?
Old 12-22-2006, 01:18 AM   #13
PetersRedYaris
Do you want to base your drop purely off looks or do you care about ride quality. TRD's and NF210's will ride better than DF210's or Teins.
Of course ride preference is an opinion.
Old 12-22-2006, 01:19 AM   #14
bigsky2
Cousin Vitz
bigsky2's Avatar
Yes, the steelies are 14".
Old 12-22-2006, 01:20 AM   #15
bigsky2
Cousin Vitz
bigsky2's Avatar
There shouldn't be, provided you get same profile tires for the 15" alloys (185-65-R15) or lower profile tires for the aftermarket 15" wheels.
Old 12-22-2006, 01:21 AM   #16
PetersRedYaris
15 inch steelies are also stock. I believe they come with the convienience package. Also, 185/60/15, not 185/65/15, are stock here in the USA. Both of you are from Canada however.
Old 12-22-2006, 01:22 AM   #17
bigsky2
Cousin Vitz
bigsky2's Avatar
Edit:
3DR CE / 5DR LE (Canada)
Standard equipment is:
P175/65R14 All-Season Radials
It doesn't look like he got 15" alloys or 15" steelies.
OK, I stand corrected.
But he is from Canada, and they might be 14" if that was not part of his package.
Old 12-22-2006, 05:44 AM   #18
the Tein's, if i remember correctly, offer a 1.9 inch drop on all four corners (lower for the sedans, i'm assuming) with a spring rate of 3.0kg/3.5kg front/rear. those are the ones that i want to get because members here say that the rear sometimes rubs with the Tanabe springs.
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
TRD OR Eibach...i'm confused... hoahmaru Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 11-07-2008 08:25 PM
Fs: New Trd Stickers & Emblems !!!!! located in So cal Trd86 Items for Sale by private party 13 06-25-2007 04:49 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 10:51 AM
Toyota's Yaris TRD VitzBoy General Yaris / Vitz Discussion 10 07-24-2006 08:10 PM
