![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
How to get cruise control
I went to the dealership yesterday and was talking to a sales rep and one of the things I was looking for in a new Yaris would be cruise control. He told me I just need the power or sport package. However, my last Yaris had the power package, and it didn't have cruise control. So how do I for sure get it?
Do it yourself. It will be far cheaper than paying for it from the dealer, and with an 09 or 10, all you need is the OEM stalk and cable.
#3 | |
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
Of course this was after I had read the threads about cruise control install, for which you just need the stalk, and if I remember right, the price was less than $20...
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
The problem is that if you don't get one with Cruise from the factory, they port or dealer install the $300 Rostra aftermarket CC, which requires a bit of (unnecessary) labor to install.
My problem with that is in my '08 it didn't have the cruise control light in the cluster that I saw in the DIY, and I was under the impression that if it's not there, then it cannot be added. Am I mistaken?
![]() ![]() ![]() Drives: . Join Date: Dec 2008
Unless this has changed (since the Sport Package is a new thing), the Power Package is a necessity to also have cruise control, but having the Power Package does not automatically mean you will get cruise control. So if you want it that way from the dealer, you'll need to specify that cars you want to see have cruise control... in which case, they will also all have Power (and presumably, Sport) Package.
Starting in 09, they all have the two indicators on the cluster.
The power package Yaris comes with a different gauge cluster than what comes on the non-power Yaris. The power version has a light that says "cruise" when the cruise is activated. The non-power can come with a cruise but it will not be Toyota's parts. It will be the Rostra, which has the light built into the stalk. You can add the Rostra kit after buying the car.
#9 | |
2. You do not have to have the power package to get cruise. My 07 does not have the power package but it already had cruise installed by the port. |
#10 | |
Regarding your second point, I was referring to the original, factory-installed cruise control... the difference that I think you pointed out here: "The non-power can come with a cruise but it will not be Toyota's parts. It will be the Rostra, which has the light built into the stalk. You can add the Rostra kit after buying the car." |
#11 | |
If you already have the power package on a 2010 you can add OEM cruise or the Toyota's approved secondary version, the Rostra. If you dont have the power package and you have an 07 or 08, you would have to buy a whole new gauge cluster if you wanted true OEM. Although, Toyota has been installing the Rostra kit on it's non-power products for at least 10 years. My parents have a 2001 Toyota Tacoma with the same exact Rostra cruise that is in my 07 Yaris and the same that is in my co-workers 2010 Tundra. So it all depends on how much $ you want to spend. |
For 2007 and 2008, factory cruise was only available on the Sedan.
For 2009, the "new car features" section of the service manual lists cruise control as now being an option for the liftback and shows the instrument cluster placing of the indicators. For 07 and 08 the cruise control sections of the service manual were specific to the sedan. So, for 2009 and 2010 all liftbacks have the indicator on the cluster, regardless of which packages they have. |
#13 | |
![]() ![]() Drives: Yaris & Supra Join Date: Nov 2008
'08 would work, you would not have an indicator light but CScott made a module for it. ;)
Duane |
And how does it work man vs auto? And where can I get a stalk? Been looking for a couple of days and can only find "kits" for $250. Eph that.
EDIT: I lied, started finding them on ebay motors, but very few. None for Yaris. Any idea what models would be interchangeable? I assume most, if not all, Toyota stalks would be, just to save manufacturing costs, but you never know. EDIT 2: Would this work: http://cgi.ebay.com/ebaymotors/TOYOT...%3D5%26ps%3D63
#17 | |
The stalk is about $80 from the dealer, the wire is about $30 and the clutch switch is about $20. The stalk and wire can often be found on ebay or junkyards for considerably less: http://cgi.ebay.com/ebaymotors/TOYOT...item27aed252bc |
#18 | |
As for the clutch switch, possibly this?: http://www.google.com/products?q=airtex%201s5850 still trying to find the wire...
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
