#19 |
![]() Drives: Q Join Date: Dec 2009
Thanks for posting this CTScott. I just recently bought a Yaris and I'm still on my first tank, but I did wonder why the top bar lasted so long compared to the others...well now I know, thanks.
#20 |
Keep To The Code
+2!! This is quite interesting!
Completed Mods: Cruise Control, License Plate Mount, Fog Lights, Exhaust Next Mods: Tail Lights, HIDs, Tint, Rear Speaker Box & Amp(Boom Boom :P) ![]()
#21 |
Only Happy When it Rains
don't run this tank dry. If the car stops because of no fuel, you will not be able to get it started again at all, and will have to go get gas. i did it once, trying to see how far I could go on a tank of gas. I've never had a car that just simply refused to start like the Yaris did.
Colin Chapman disciple |
#22 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
![]() Am I reading this right? You're wondering why the Yaris won't restart after you stall out by running it dry? Hint: gas powered cars do not run without gas.
#23 |
I know what he means. On some cars, when they run out, you can restart them, and drive them gently (to keep the last bit of fuel as stationary as possible) a bit until they die again. The way the Yaris' fuel system works you can't - Once it quits, it's done.
#24 |
@CTScott: Is there a way to measure (in a more precise manner) how much fuel is left in the tank by using an OBD module?
#25 | |
The problem with doing it by fuel flow is that it is one way. Unless you could also read the flow rate into the tank, you'd still be working down from an approximation. |
#26 | |
#27 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
it will sputter a bit then run good, alerting you that only minutes remain and you are walking..... my 4runner does that with <1/2 gallon left it dies. you stop, wait, start again. in 3 miles it dies again. start back up, you have 2 miles left, at most |
#28 |
My favorite Mythbusters explosion!
![]() Mythbusters - Compact Compact Rocket Sled Thank God it wasn't a Yaris at the end! ![]() Cheers! M2
#29 |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
100 % useable? great! I don't much care how long the first bar or two takes, its the apparent speed up of the flashing last bar, usually when I'm some distance away from a station, that always gets me by surprise. My other Toyota is exactly the same in that respect, it seems to go from 3/4 empty to empty real quick, I've learned to ignore it, to some extant, and have never run out totally. Knowing what I know now, I'll probably push it even more! 10.48 gallons at my last fillup, just right.
#30 |
DAT'S RIGHT I GOTz 2
commom sense will tell you if you close to empty
"only got 1 bar left" ....get gas.... pay now or pay later
#31 | |
#32 | |
#33 |
![]() Drives: 2008 Yaris sedan, 5 speed Join Date: Apr 2012
I don't understand why anyone would want to let their fuel level drop to less than a 1/4 of a tank as I was always under the impression that any crud that may have been accumulated from using "dirty" gas is usually sitting at the bottom of the tank.
I know of 2 people who ran out of gas and a short time later - their fuel pumps died (one of them was a Chev Montana van and the cost to repair the fuel pump was $750.00). |
#34 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
I almost always run it down leaving just about 1 gallon left. It helps me to keep track of my mileage more efficiently (by glancing at the trip meter). As soon as the last bar blinks, I use the trip meter to confirm how much gas I have left and plan the gas run accordingly.
#35 | ||
Not to mention if you run the tank lower, none of that crud ever has the chance of building up since it is all used.
#36 |
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
I never let my car run out of gas, but I have the same thing as AAA included in my car insurance. It covers towing, flat tire changes, locksmith, battery jump-starts, and fuel/fluid delivery for $2.00 addl. every 6 months. So far, haven't had to use it with my Yaris for anything (knock on wood) but when I had the Cavalier I took advantage of it 3 times for flat tire changes.
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| GET FREE PS3/360/Wii check it out! | marcus | Off-topic / Other Cars / Everything else Discussions | 23 | 09-25-2007 06:51 PM |
| Low fuel light | falkor_99 | General Yaris / Vitz Discussion | 35 | 08-24-2007 03:20 PM |
| Fuel Level Gauge Stuck ? - 2007 Yaris Sedan | kaboom | New YARIS Purchase Forum | 9 | 05-15-2007 02:58 AM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
