Old 12-14-2006, 06:33 PM   #19
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Hey Violin,
Since you mentioned going the with a full retrofit, I wanted to point out that the Denso OEM HID kit will not work in a plug and play situation. It will only work if you perform a retrofit like Violin plans to, or if you already have an existing OEM HID system.
OEM kits cannot "plug and play" into non-HID headlight systems without some modification.
Thought I'd share that distinction between OEM HID kits and HID Conversion kits.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 12-15-2006, 11:33 AM   #20
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The Denso kit that I linked to will work in a plug & play situation. The bulb has an extra groove machined into the base that holds it correctly in the included casper shield that fits in the H4 bulb space. It comes with spade plugs to plug into the stock H4 harness. That is OK for short term but you should really buy/make a new wiring harness with relays so the ballasts are powered from the battery or you will fry your wiring (or worse) over time.
Be aware that we have a switching ground setup - meaning that the positive is always on and the ground is switched on and off. It is extremely important to get the polarity correct.
Old 12-15-2006, 04:33 PM   #21
bigsky2
Cousin Vitz
bigsky2's Avatar
Good advice, thanks for clearing that up.
As for the wiring harness, you might want to check out this if you haven't found a solution yet:
Info at:
http://www.mobilehid.com/products.htm#wires
Old 12-16-2006, 05:08 PM   #22
Violin
Violin's Avatar
Correction - no it won't.
This is how it's supposed to hold the bulb and adapter:
Below is how ours looks:
Old 12-16-2006, 05:11 PM   #23
Violin
Violin's Avatar
Not that big a deal to me as Ken at Sparks Toyota is hooking me up with a pair of stock headlight housings at a reasonable price and I'll be starting my full retrofit any day now. Photos to follow.
With some modifications to our bulb holder, I'm sure the kit I linked to above could be made to work and it is quality parts that will last a very long time.
Old 12-16-2006, 05:16 PM   #24
Violin
Violin's Avatar
BTW - there is room under our headlights to mount the ballasts. I used double sided super heavy duty mounting tape and two small screws to attach mine like so: (Be very careful drilling into the housing and use the shortest screws that will reach as there is limited space between the black ABS outer housing and the reflective inner housing - but there is space. I used 1 1/4" screws.)
Old 12-16-2006, 05:45 PM   #25
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Looking good.
Old 12-17-2006, 05:31 PM   #26
elsteverino889
elsteverino889's Avatar
Drives: 2007 Yaris sedan black
can you take pics of the final product and the light also?
elsteverino889 is offline   Reply With Quote
Old 12-18-2006, 06:47 AM   #27
Violin
Violin's Avatar
Oh I will - don't worry.
Old 12-22-2006, 12:28 PM   #28
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
Originally Posted by iloveyarisRS View Post
yes, I was brought from e-bay....
the price is very good.....
http://cgi.ebay.com/ebaymotors/ws/eB...0401475&rd=1,1
I found it !
jimcat is offline   Reply With Quote
Old 12-23-2006, 10:35 AM   #29
tonywenzel
Drives: Z33, NCP91
Yea those are not "real" Bosch. It is clearly a chinese company infringing on copyrighted logos and trademarks for marketing purposes. Beware.
tonywenzel is offline   Reply With Quote
Old 12-23-2006, 02:27 PM   #30
Chris07LB
Chris07LB's Avatar
Welcome to the wonderful world of eBay.
Where's our vendor that was pushing his low budget HIDs on here months back? One member bought, posted problems, and I've yet to see the vendor post ever again.
You get what you pay for people.
