Old 12-24-2006, 11:20 AM   #19
graywolf_14
Drives: um not a yaris but hopefully
um
Um not as heavy as metal but I ment carbon fiber anyways my bad.
graywolf_14 is offline   Reply With Quote
Old 12-24-2006, 03:53 PM   #20
Tamago
Tamago's Avatar
Drives: UZJ100
if you want it strong it's heavier than metal (fiberglas, not CF)
Old 12-24-2006, 04:22 PM   #21
dngz
dngz's Avatar
Drives: black yaris sedan
Originally Posted by eco View Post
I never said take out the jack stand,and I meant copy only the pages from the manual that you needed,maybe 3 pages,that weighs nothing compared to the manual.
well if i took out the spare tire, i mite as well take out the jack stand =P!! i wouldnt mind getting a CF hood, roof, and trunk though.. thatd be sweeeeet...
dngz is offline   Reply With Quote
Old 12-25-2006, 01:59 AM   #22
graywolf_14
Yeah I wish I had 1k to spend on a hood that would be sweet.
Old 12-25-2006, 02:41 PM   #23
spkrman
Drives: 1
hood/roof/trunk would be AWESOME on your car
Old 12-25-2006, 06:02 PM   #24
03Z33
03Z33's Avatar
Drives: TCR10
I believe somebody already mentioned the battery... I replaced my stock battery with an Odyssey PC680MJ for $80 and saved 22lbs.
You may also consider some drivetrain upgrades such as LSD and clutch/flywheel. They won't help you gain power, but will be a lot more noticeable in day to day driving as well as help you put power down to the ground
Old 12-25-2006, 06:15 PM   #25
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Where did you find those battery's for the best price? Im looking for 3, instead of going the Red top route.. thanks
Old 12-25-2006, 06:43 PM   #26
03Z33
03Z33's Avatar
Drives: TCR10
http://www.odysseybatteries.com/
Make sure you specify "MJ" for metal jacket at the end of the part number for automotive use. I use the PC680MJ and it's a direct replacement, just needs a small block of 2x4 wood on top to make up for the height difference since the stock battery is taller. I'll snap some pics soon.
Old 12-25-2006, 11:31 PM   #27
Not to sound too much like a n00b, but what would be the effect of a LSD on the handling of the car? From what I can understand, would it not create understeer when accelerating in a curve?
Old 12-25-2006, 11:34 PM   #28
Tamago
Tamago's Avatar
Drives: UZJ100
accelerating in a curve creates understeer to begin with as you're shifting weight away from the wheels that steer.
understeer allows you to put down more power in a tight corner. trust me, an LSD would be one helluva mod on a car this light, especially if you've added a stiffer front swaybar.
Old 12-25-2006, 11:37 PM   #29
03Z33
03Z33's Avatar
Drives: TCR10
Best way to describe it, is you ever step on the gas pedal "too early" coming out of a tighter turn and notice one of the tires starts slipping? An LSD will prevent that by sending more torque to the other tire that has grip allowing you to "pull" through the turn. It makes a night and day difference and is by far one of the most noticeable improvements you can make to any car!
Old 12-25-2006, 11:49 PM   #30
Hmmmmm most interesting, I shall have to add that to my "to-do" list
Old 12-25-2006, 11:55 PM   #31
03Z33
03Z33's Avatar
Drives: TCR10
For sure! If there's interest I can look into organizing a group buy... KAAZ make the best LSD for our cars and have plenty in stock here in California. I'm just saving up a little more, since I want to change clutch, flywheel, and final drive all at the same time.
Old 12-26-2006, 02:43 AM   #32
hmmm OK... what's an estimated price for that? I'll have to look into the TRD LSD as well, as it would be more readily available here.
Old 12-26-2006, 03:02 AM   #33
03Z33
03Z33's Avatar
Drives: TCR10
The TRD and KAAZ units are both very similar, in that they are both 1.5 way mechanical LSDs with clutch packs. The KAAZ unit has more plates (also larger) for better lock and is adjustable from 60-100% lock.
TRD LSD part #41301-AW004 $945US Retail (not available in USA)
http://www.trdparts.jp/parts_lsd_mechanical.html
KAAZ LSD part #DBT1621 $925US Retail (In stock, available in Japan and USA)
http://www.kaazonline.com/dbt16211.html ($832.50 sale price direct from KAAZ)
www.kaazusa.com
www.trdparts.jp
Old 12-26-2006, 03:06 AM   #34
Ok cool... I'll ahve to check how much the TRD distributor here wants for it, and the shipping costs for the KAAZ one... We'll see
Old 12-26-2006, 03:09 AM   #35
03Z33
03Z33's Avatar
Drives: TCR10
Please let us know if you can get the TRD ones... It would be great to have a reliable source for those too
