Yes- I fit in it.
Issue when starting..
I have had this happen a few times. I turn the key to start the car and it is almost as if the car "half starts." It is running, but seems as if it is severely missing and the starter is still cranking. If I shut it back off and then start it again, it is fine. Again, this has only happened a few times. Any ideas?
I'm surprised it doesn't have a pull-start ! |
![]() ![]() Drives: Meteorite Yaris Liftback Join Date: May 2007
Sometimes out of the blue my Yaris will crank for a long time with my hand off the key until it finally starts and sound kind of odd at first. Then, after that starting up is fine. Not sure if it's the same issue you are talking about but it has been doing it for the past 3 years on rare occasions and it's been 100% reliable.
A few times when my car didn't start immediately, and it continued to crank all by itself until it started! Interesting feature.
Yeah, you just twist the key and let go right away and the car self cranks itself.
![]() I thought something was wrong with the car when I first got it. Then I wondered why there was such a huge delay between stepping on the gas and the car actually moving. I hate drive by wire....
![]() ![]() Drives: 2010 Yaris ce Join Date: Jan 2010
the 010 drive by wire seems to be way better then the 08's if you try a throttle control it would help with the throttle response
the starting issue any mods to your car?
![]() ![]() Drives: '10 Yaris 3 door HB Join Date: Jan 2010
I learned this week by accident that a quick turn of the key starts the car. nice feature for sure
Learn to Relax
You might want to run a fuel system cleaner.
Half a Bubble Off Plumb
There was a long thread about this last year, and as I recall several folks said they'd fixed the problem by holding the key turned to the start position till it started, and NOT just quickly blipping it over to start and back to run, letting the computer handle it. Try searching the archives.
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| heater control box issue | DevilGirl | DIY / Maintenance / Service | 12 | 01-08-2010 03:45 PM |
| Problems starting the engine | fmicle | General Yaris / Vitz Discussion | 10 | 10-07-2009 08:48 AM |
| CONSUMER REPORTS : MARCH issue reviews '09 YARIS . | gid | General Yaris / Vitz Discussion | 93 | 01-06-2009 04:10 AM |
| Starting Engine - Yaris Hatchback M/T | gbuks | General Yaris / Vitz Discussion | 2 | 11-06-2008 12:24 PM |
