Old 02-12-2010, 05:53 AM   #1
bf1120
Drives: Vitz
Need help with airbag light on....
my car's keyless entry didn't work, airbag light (both) on, passager's seatbelt light on (no one sitting there), immibilizer didn't work, whenever i start the car, the time always reset to 1:00, the lock/unlock button doesn't work without i start my car.....
anyone know how to solve and what happened?
need help please....ASAP......
bf1120 is offline   Reply With Quote
Old 02-12-2010, 07:38 AM   #2
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
If the passenger airbag light is on as well as the seatbelt light, you need your airbag system re-calibrated. This happened to me after a rear-end collision. This was covered for me by insurance so I have no idea how much it will cost.
devinlamothe is offline   Reply With Quote
Old 02-12-2010, 07:48 AM   #3
This post explains how to get the SRS ECU to flash its light to tell you what the stored codes are:
http://www.yarisworld.com/forums/sho...0&postcount=78
This one explains how to reset the stored codes:
http://www.yarisworld.com/forums/sho...&postcount=205
Some of the stored codes require individual resetting, so if you have 3 stored codes, you may have to do the reset procedure 3 times.
Old 02-12-2010, 04:35 PM   #4
bf1120
Drives: Vitz
find out what happened....the ECU-B fuse burned.....
Old 02-12-2010, 04:47 PM   #5
Ahh, that makes sense, especially with the clock always being reset...
Old 02-12-2010, 08:51 PM   #6
bf1120
Drives: Vitz
but right now my fog light doesn't work.....it works when i didn't start the engine, but when i start my engine, the fog light it's gone....when i turned it off, the fog light on again...
Old 02-12-2010, 09:27 PM   #7
Check the ECU-IG fuse.
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Anyone get the Check airbag light to go away when you installed racing seats or wheel wholenizz Cosmetic Modifications (Exterior/Interior) 1 06-17-2009 08:14 PM
Airbag light is on Taiyaki DIY / Maintenance / Service 4 05-26-2009 08:47 PM
