Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 11-11-2009, 08:22 PM   #19
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
What cat back??? Is there a cat back for the Yaris?
I think Magnaflow came up with one sometime ago but the price was crazy.
Custom exhaust FTW!
Old 11-12-2009, 11:38 AM   #20
tcpty
TSport Underdog
tcpty's Avatar
Drives: 2008 TS Storm Gray
Custom exhaust FTW!
Sorry Castrex. My Bad.... "Axle Back"
But, do you know if they fit the TS?
tcpty is offline   Reply With Quote
Old 11-12-2009, 01:02 PM   #21
CASTREX
CASTREX's Avatar
The axlebacks will bolt on... as the exhaust is the same. However I'm not sure at how the exhaust tips would line up with the TS bumper. You know since our bumper has that shape for the exhaust tip. The tip from some of the US axlebacks might not align properly... and that would look really bad.
IMO... go custom! I can give you some suggestions depending on what you are currently looking for. I actually have 2 custom exhaust for my TS... a loud one and a semi quite one... I can swap them in a matter of 15min.
Another reason why the custom route is better than the off the shelf axleback is because you can get rid of the tiny and crushed pipe that goes from the cat back to the axle.
Old 11-12-2009, 03:05 PM   #22
tcpty
TSport Underdog
tcpty's Avatar
OK, Thanks for all the info! I just wanted to know if the exhaust were "compatible" And, yes, the tip was a concern of mine with our rear bumpers and the bolt-on compatibility for our TS's
There are quite a few options available for the Yaris. I would definitely would not go "loud" but wanted a freer flow than stock to continue the small performance gains. IMO "loud" does not necessarily means faster and a well "proven" or R&D'd aftermarket exhaust is worth the money because of "that" proven track record if they can back up their gains claim. Time sheets do not lie.
Old 11-12-2009, 04:03 PM   #23
CASTREX
CASTREX's Avatar
The problem is that achieving high flow and quietness at the same time would be close to imposIble!! Most axlebacks for the Yaris are really loud.
This is what I did...
I replaced the entire exhaust from the cat back. I even went as far as removing the secondary cat. Yes, in case you haven't noticed our cars come with 2 cat converters. I removed the secondary one and haven't had any problems.. the car passes the emissions testing and all.
I used 2.25" diameter pipe all the way back.
Initially I used 2 round Magnaflow mufflers. 1 installed in place of the OE pre-silencer and the other one at the back right before the tip.
The car felt great!! and the sound was awesome...
http://www.youtube.com/watch?v=A6Pp1IuJzG8
But it was a little too loud... a bit annoying specially during long trips...
So I had a flanger welded right over the axle and made a second axleback section using a chambered oval muffler...
I can still feel a difference over stock and the sound is just a bit louder than stock...
Good thing that I can swap between the 2 axlebacks in a matter of 15 min. From the straight thru Magnaflow to the Chambered one...
Usually drive around with the chambered muffler and install the Magnaflow when I go for out for a fast drive.
When I get to complete my turbo set up I'll just keep the magnaflow as the turbo should help a bit with the noise...
Old 11-15-2009, 01:53 PM   #24
oxide666
SR Badboy!
Drives: 1.8 sr Chilli red
there is a few i have sin
a sebring axleback i orderd will be instaling as soon as i get and a TRC/fox
sebring ment to be gd not to loud not sure about the trc
oxide666 is offline   Reply With Quote
Old 11-15-2009, 02:41 PM   #25
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
Yeah good info.
chongopants is offline   Reply With Quote
Old 11-19-2009, 03:43 PM   #26
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
I tried to install my Tanabe Touring Medalion exhaust last week. It won´t fit the TS as the tail pipe is placed to the right for the tail pipe cut in the rear bumper, so it doesn´t look good at all.
Regards Steven.
Danish Yaris is offline   Reply With Quote
Old 11-19-2009, 06:06 PM   #27
CASTREX
CASTREX's Avatar
Good to know...
That's what I was afraid.... the tip not aligning properly with the bumper.
Old 11-19-2009, 07:14 PM   #28
tcpty
TSport Underdog
tcpty's Avatar
Thanks for the heads-up Steven!
As Castrex said, good to know what works and what doesn't!
Old 11-23-2009, 08:29 AM   #29
oxide666
SR Badboy!
sebring fits well no probs
Old 02-02-2010, 01:35 AM   #30
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
will the TS engine fit the US spec yaris?
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 02-03-2010, 11:05 PM   #31
tofuufot
Drives: 3dr 2010 yaris
no one knows?
tofuufot is offline   Reply With Quote
Old 02-03-2010, 11:40 PM   #32
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I don't see why it wouldn't.
Old 02-11-2010, 04:02 AM   #33
barebonedvitz
it should right? has anyone tried it yet?
Old 02-11-2010, 04:05 AM   #34
barebonedvitz
it should right? anyone know who's done it yet?
Old 02-13-2010, 03:05 PM   #35
lammy29
Drives: Yaris
just wondering oxide666, where you get the sebring from?
lammy29 is offline   Reply With Quote
Old 02-13-2010, 04:14 PM   #36
CASTREX
CASTREX's Avatar
You do realize the TS engine is the same as the scion xd and the scion xd and yaris share the same chasis platform.
In other words you just need an engine and a ECU out of a XD to do the swap.
No one has done it because the gains do not justify the investment. If you have a yaris with a broken engine on ther other side... this swap would make a lot of sence
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 10:08 AM
The official Yaris Taillights thread Razr Cosmetic Modifications (Exterior/Interior) 40 06-12-2007 10:08 AM
