Old 02-14-2010, 10:35 PM   #19
Are Hefty bags good enough to store R comps in?
Old 02-15-2010, 02:43 AM   #20
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
They might be good if you stuck the tires in the fridge. Take it from someone who used to hide in Hefty's as a kid while playing hide-n-seek with the cousin, there's no air-condition in there! LOL
Old 02-15-2010, 03:22 AM   #21
SilverBack
Joey
SilverBack's Avatar
Originally Posted by kngrsll View Post
what exactly is your budget??
for ST competition- wheels, tires, shocks, springs, and a rear sway bar will be: $4-500 for 15x7's, 85x4 for street tires, 150 for a rear sway bar, 200 for springs, 350 for shocks and you can do fairly well in ST. thats under $1500.
for hoosiers and light weight wheels, you are looking at nearly the same! $500 for light cheap wheels and $800 for tires. for a little more, you can have the suspension mods and drive on your autox set up everyday (which is still more tame than alot of mid range sports cars)
im not trying to argue, just providing an alternative.
Good call. Who's offering $85 each for R-comps BTW? And $500 for wheels? Just saying I could always use a better deal. And my springs are already installed with sway bar next.
So far I've got my heart set on the lightest rims I could find (MSRP about $800/set, but will keep looking for better price) + tire budget (limit $800/set). Total of $1600 sounds about right, though it could be much lower depending on chosen tires and certain retailers. My local tire guy always gives me a good deal so I'll see if he's got what I want first.
Old 02-15-2010, 10:37 AM   #22
Jason@SportsCar
Originally Posted by SilverBack View Post
Good call. Who's offering $85 each for R-comps BTW? And $500 for wheels? Just saying I could always use a better deal. And my springs are already installed with sway bar next.So far I've got my heart set on the lightest rims I could find (MSRP about $800/set, but will keep looking for better price) + tire budget (limit $800/set). Total of $1600 sounds about right, though it could be much lower depending on chosen tires and certain retailers. My local tire guy always gives me a good deal so I'll see if he's got what I want first.
If you have changed your springs your car is not legal for HS. A rear bar is also not legal for stock class.
Old 02-15-2010, 12:40 PM   #23
kngrsll
Apexing Egg!!
kngrsll's Avatar
making ST even more appealing ;)
you could get these if you still want RA-1's: http://www.good-win-racing.com/Mazda...t/21-0046.html
$900 for wheels, tires, mounted, and balanced? win
or put, street tires on them, use the rest of your budget at microimage on a rear sway bar and shocks and you are can run ST and do track days to your hearts content!
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-15-2010, 01:10 PM   #24
SilverBack
Joey
SilverBack's Avatar
I'll check in with my shop tomorrow when they open first, but I'll bookmark that link for now. Thanks!
I see about the springs. I'm also running Falken ZE502's. Does this mean I can move up to ST? If not, then which class?
Man this is confusing...
Old 02-15-2010, 01:14 PM   #25
Jason@SportsCar
Yes, you can run in ST.
Old 02-15-2010, 01:25 PM   #26
SilverBack
Joey
SilverBack's Avatar
Sweet! Thanks for your help Jason
Old 02-15-2010, 03:02 PM   #27
Jason@SportsCar
Keep in mind none of the tires you were looking at are ST legal - must have a 140 or higher tread wear rating for ST.
Old 02-15-2010, 03:46 PM   #28
SilverBack
Joey
SilverBack's Avatar
I guess I'll just have to use the Falkens again for the next event and just grab a sway bar and CAI way before. I can still wait a minute to get rims and tires seeing as how I need to make enough storage space for them anyway. Can I still run the sway bar and CAI in ST? I'm looking at the class rules right now, but doesn't really say anything specific about engine and suspension parts til you get to SP.
http://www.sfrscca.com/solo2/faq/auto.htm#114
I take it "common parts" also include CAI? Or is it limited to a filter-only upgrade? Is sway bar also considered common?
Old 02-15-2010, 04:00 PM   #29
Some classes limit you to options that would come from the dealer. It's confusing to me that's for sure.
Old 02-15-2010, 04:00 PM   #30
Jason@SportsCar
Those are not the rules: http://scca.com/contentpage.aspx?content=61
You want to look at section 13-19, specifically for Street Touring.
Old 02-15-2010, 04:03 PM   #31
Jason@SportsCar
Dealer installed options are not legal in stock class, only factory or port installed options.
Typically any class beyond stock you would use an aftermarket part that is better than the dealer install stuff, so it becomes a non issue.
Old 02-15-2010, 05:35 PM   #32
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Yes, heavy-duty black trash bags are more than adequate for storing tires in.
The goal is to keep them isolated from ozone, sunlight, and temperature extremes.
Old 02-15-2010, 05:35 PM   #33
SilverBack
Joey
SilverBack's Avatar
Okay now it's making even more sense. Getting there slowly lol. I checked the SCCA page several times before that. Not sure why I couldn't find it...
Old 02-15-2010, 05:50 PM   #34
Jason@SportsCar
The website is not super user friendly, and the rules can be even less so - particularly in the state they are in. Typically it is one link on the site for the whole book, and you even get a side menu to find the section you want, but at the point they put it online they were not 100% done.
ST will let you do a lot of things to make up for the lack of the stock classes sticky tires: CIA, header, cat-back, ECU, pulleys, shifter, suspension, race seats, wings.
Just for comparisons sake... We took our stock class RX-8, that had won four strait BS championships and converted it to STX in 2009. The difference in prep between stock and STX was about $10k, and the car was slower in STX trim - it is no longer in STX trim. I like race tires.
imho it is hard to beat the transformation that occurs when you put race tires on an otherwise "stock" car. The comfortable daily driver feels like a racecar with just a simple tire change. While an ST car reminds you on a daily basis with its poor ride quality, noisy exhaust and limited ground clearance. And in almost every case a stock class car on race tires is quicker than a no expense spared ST car. Spend more money to go slower? No thanks.
Old 02-15-2010, 06:29 PM   #35
kngrsll
Apexing Egg!!
kngrsll's Avatar
well ST is very appealing to me in my current situation. I have the yaris with a few bolt ons. springs, shocks, rear sway bar, a header, and intake. Those are pretty cheap common mods around here. Now you have the option to compete in ST or FSP based on how much you want to spend on tires. I prefer to just run in ST and use my street tires. Will i compete on the national level? nope, will i be competitive at a regional level? highly doubt it. but is it a great class to arrive and drive when i get the chance? hell yeah! so ST works for alot of people, and i think thats really why they created the class.
now what i would REALLY like to do is run an S2k in stock class with R-comp's. THAT would be fuuuun!
Old 02-15-2010, 06:33 PM   #36
kngrsll
Apexing Egg!!
kngrsll's Avatar
Here is a chart someone else posted here for your help:
http://autocross.com/er/carmodandclassification.pdf
now that you have decided on a class, picking a tire will be easy. The fastest tire last season was the R1R, but they will not last long if you use them on the street. If you are only bolting them on to race with, they would probably be your best choice. The next best would probably be the Kumho XS or Direzza Star Spec. I love my star specs, i daily drive them, autox on them, and do track days on the same tires, they are amazing pieces of rubber! ST allows you to run up to a 225 tire on a 7" (or7.5"?) rim. you can still do alot of parts, springs, shocks, (or coilovers), rear sway bar, seat, header, intake, exhaust, and i am sure there are more.
Links:
http://www.tirerack.com/tires/tires....t+Z1+Star+Spec
http://www.tirerack.com/tires/tires....Model=Ecsta+XS
http://www.tirerack.com/tires/tires....VAN+Neova+AD08
http://www.performanceplustire.com/p...490#prodAnchor
THE BEST AUDIO SPEAKER phenoyz77 In Car Entertainment + Electronics (audio / video / alarm) 58 01-20-2010 10:46 PM
FS: Waterloo, ON: 14's and r comps thebarber Items for Sale by private party 7 01-21-2009 06:02 PM
