#37 |
![]() ![]() ![]() Drives: Toyota Yaris 1,8 TS 5dr. 2007 Join Date: Dec 2008
Hi
I was wondering if you could swap the ECU with one from a Toyota Avensis/Auris/Verso 1,8 Dual VVT-I? They have got 147hp. instead of the 133hp. in our Toyota Yaris 1,8 TS. Look at the specifications here: http://www.toyota.dk/cars/new_cars/a...fullspecs.aspx I think itīs the same engine, so I would think itīs just the ECU thatīs decide the amount of hp. Does anybody know if it could be done? Regards Steven. |
#38 |
Show & Go
Hi.
Itīs not the same engine. So, swapping ecu makes no different for yaris. |
#39 |
Hi
Are you sure itīs not the same engine, as they are both 1,8 Dual VVT-I? Itīs not a VVTL-I like the Toyota Corolla TS. Regards Steven. |
#40 | |
http://en.wikipedia.org/wiki/Toyota_ZR_engine#2ZR-FE the new 1.8L (147HP) engine has 2ZR-FAE and TS engine has 2ZR-FE code.one letter is missed from our engine .the diference betwwen torque is not much-5NM.and the new engine has Valvematic system.
#41 |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
Just wondering if the in cabin shifter fits and both of the brushings aswell.
#42 |
Drives: Toyota Yaris Join Date: Mar 2010
Hi All,
I have a question regarding to the speedometer cluster of my yaris sedan 07. I'm interesting in swapp the cluster for a 2010 the only different is that mine just have one clock and the 10 has 2 one for the miles and the other for RPM but I'm not sure if I do a swapp the RPM gonna works or just is plug and play? excuse me for the inglish I'm from PR so someone could help on this, please. Thanks |
#43 | |
return of the comeback
Drives: white '08LB..very nice,i like Join Date: Mar 2007
Everything will be ok in the end... if it's not ok, it's not the end. 93 Civic Si- SC/B18B1 - street beast 07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K. 08 White Yaris LB - daily beatnut...round 2! |
#44 |
Chris
Drives: 2007 Yaris S Join Date: Dec 2009
I hav a stock intake with just a regular k&n filter. Do you think upgrading to a CAI would make of a difference? I need something to do on my car so if a did that I might get a throttle body spacer too.
#45 |
![]() Drives: Fit, Scion XA, '91 Ford Festi Join Date: Feb 2010
I want to use my Yaris hatchback on rough backroads, so I could use more ground clearance. The Scion xd has 6 1/2" ground clearance vs the Yaris' 5 1/2". Anyone know the length of the xd's springs?
#46 |
http://www.remusuk.com/model.asp?id=...0II&man=Toyota
tempted to buy it but dunno what it sounds like.... http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories is the rear sway bar easy to fit? Last edited by lammy29; 09-13-2010 at 09:06 PM. |
#47 |
![]() Drives: 2000 Yaris 1.0 & 2007 Yaris Ts Join Date: Sep 2009
How much of a difference you get with the NST pulley?
It just improves the will of the car to rev in simple words right? No actual hp gain or..... |
#48 |
#49 |
![]() ![]() Drives: Yaris SR 1.8 Join Date: Sep 2010
I'm interested in the NST pulley but there's a video on youtube of a failed pulley, bearings came loose in the centre or something...now I'm worried.
#50 |
#51 |
![]() ![]() Drives: sr Join Date: Jul 2011
-scion xd 1.8 2zrfe weapon r header
fits %100 |
#52 |
#53 |
Drives: 2005 Echo Join Date: Dec 2012
I have '05 Echo brake parts that I was going to put on my Echo hatchback before it was totaled in an accident.
Now I'm looking to purchase a 2011 Yaris. Does anyone know if my '05 Echo brakes (Rotors, pads and brake lines) will fill on an '11 Yaris. Thanks |
#54 | |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
I read Scion xA and xB models do, at what age range do they work for the echo? I'm really looking for suspension parts, |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 31 | 10-20-2025 09:08 AM |
| The official Yaris Taillights thread | Razr | Cosmetic Modifications (Exterior/Interior) | 40 | 06-12-2007 09:08 AM |
