![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Compression Question...
*For d ones who don't know* I own a yaris 2001 with a 1NZFE turbo engine.
I had seen many threads showing built 1NZFE engines for turbo through out my research and I noticed that many of them use CP pistons or other brands with a compression ratio of 9.5:1. Well mine seems to be the only 1NZ with 8.5:1 compression arias pistons... From the beginning of my project I always had\have issues in slow running and idling so I am suspecting if these issues might be due to the lower compression
Learn to Relax
What happens if you raise you idle a little? Maybe you have other issues, like valve problems?
mine are 9:1 -- I'm pretty sure. Your car should idle ok.
#4 | |
When slowly pushing the gas from 2000 till 3000rpm, the engine knocks several times. After 3k rpm kicks in VVTI & boost and the engine shows us real performance till 6500rpm. I know some should say it's a tuning problem and maybe it is... but it's really hard to get it stable within 2K-3K rpm range especially when you try to lean it out more than 10.5 AFR |
| Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 12:59 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Feeler question? | Cutie Pie #2 | Items for Sale by private party | 4 | 08-18-2009 04:03 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| dealer trade-in payoff question.. | kapo | New YARIS Purchase Forum | 1 | 07-16-2007 10:27 PM |
