![]() Drives: 2006 YARIS RS Join Date: Jul 2009
ABS LIGHT & E BRAKE LIGHT
Hi,
I started my car this morning and the e break light did not turn off and the abs light was on. When I was coming to a complete stop the ABS was kicking in even though I was not slideing? It only happened a few times, then stopped but the lights are both still on. I then tried to slam the break in the snow to see if the abs would kick in...but no luck, it seems like the abs stopped working. Any ideas? Has anyone come across this issue? Thanks A.R |
Get a coffee and read on.
http://www.yarisworld.com/forums/showthread.php?t=11533 http://www.yarisworld.com/forums/showthread.php?t=11355
Thanks
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Welcome to our wonderful world of broken speed sensors and wiring harnesses.
![]() ![]() ![]() Drives: Loaded 2007 mica silver sedan Join Date: Sep 2007
Yup, read the above links. I too have had the same problem here in New Hampshire. Parts have been on back order for 2 months. If you have less than 36000 miles on the car it will be taken care under warrany and a TSB posted in June of O8. If not and you don't have the extended warranty it'll cost you between 300 to 500 dollars PER side to fix. Talk with your dealer. Brakes will still work but the ABS will not work. Lights may go out in a day or so or they may not. Good luck
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
hey, better than bmw with their fiber optic network and broken hardware....not to mention their continusous upgrades to software.
sorry, bmw tech |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 02:59 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Emergency brake light is on constantly | AdeJong 03 | DIY / Maintenance / Service | 9 | 10-10-2009 09:32 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
