#37 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Altitude is right, get it out of there.
Be sure to drain it into something clean in case you let out too much. If you happen to be too low, you can take the same oil and put that back in. Since this time you aren't doing a change, let it out when the car is compeletly cold so you won't burn yourself. Try to let out what you think to be 1 or 1.5 quarts, even 2 quarts, close things up and check the dipstick. If you're low, fill up to the half and check twice. Warm up the engine and check twice again. Try to get it to the half-way point and you should be good. Good job, your next change should be a cinch.
#38 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
I drained about half a quart out and now the dipstick measures exactly at the full mark.
Is that fine or should I really have it around the half way mark? |
#39 |
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
It's best to have the oil level as close to the middle mark as possible or at least from half to full. The oil level isn't like the brake fluid or other fluids where you should be at the full mark. For now you should be okay.
#40 |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
I just wanna add this little gadget I found on the net http://qwikvalve.com/home.php Its a drain plug like a faucet for easy oil change.
#41 | |
she was an American girl
#42 |
SIPNDEW
thats the fumoto valve. ive got one and i love it.
#43 |
![]() Drives: 2008 Red Yaris Join Date: Aug 2009
Group buy on Fumoto Valve and discount code
I was looking around for the best price on the Fumoto Valve (F103) and found a link on ToyotaNation and a discount code for it. It makes the final price including shipping $24.65.
http://www.quickoildrainvalve.com Discount code: YM4 |
#44 |
http://www.quickoildrainvalve.com/Se...ts.asp?Cat=187
That's a great buy. Choice of two valves. 'With nipple and without. Both work great but if you ever want to get a underpanel like the one Microimage has, the one witht he nippled extends out enough to impeded the panel form being installed without adjustments. I have the one with the nipple, grea for attaching a hose so you can drain more easily, but now I have to adjust the panel. I don't have it on right now.
#45 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
At any rate, Toyota says 5w30. Some engines, Yaris' included, use the engine oil as hydraulic fluid to do certain things. (Yaris' vvt-i engine uses it to control the valve timing.) So messing around with non-spec viscosities *can* have unintended consequences. Use what the filler cap recommends. |
#46 |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
I want to know what the Deal is with the FRAM oil filters?
Problems or just a personal preference?
#47 | |
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
The cheapest Fram filters (the "orange can") have gotten a bad reputation. It may be deserved or it may not. There are plenty of anecdotal stories of Frams letting people down, but anecdotes are not proof that Fram's are any more prone to failure than any other cheapie brand. The main point of contention seems to surround the use of paper-like fiber end caps on the filter element instead of something more substantial (like, you know, METAL!). The more expensive Fram models seem to be made a little more stout and you don't hear as many complaints about them. I've used Frams in the past, there are millions of cars on the road using them now, and, if I couldn't obtain anything else, I wouldn't have a problem using one today. But they are way down on my list. From Amazon, I can get Purolator Pure One's for about $4.75 or Denso for $3.94. Better filters for about the same price. Last edited by Happy Little Pony; 03-03-2010 at 03:00 AM. |
#48 |
Ive used FRAM filters for 30 years. 1973 Chevrolet Bel Aire 153,000 miles.
1978 VW Rabbit (my parents car which I maintained) 120,000+miles. Not 100% FRAM filters but more than 75%. No problems that I can see. |
#49 |
![]() Drives: 2007 Yaris Hatchback Join Date: Aug 2010
thanks for this post. it was a big help, I was able to switch to synthetic oil and save some money......
Utinam barbari spatium proprium tuum invadant! May barbarians invade your personal space! |
#50 |
![]() Drives: 2008 yaris sedan Join Date: Aug 2010
5w20 oil
In the last 10+ years almost every japanese import calls for 5w20, mostly for its mpg. It gets to be over 115 degrees at times in this area, Far Northern California (Redding) and as cold as +15 degrees, and I have had no problems using this weight of oil. I have used it in Subaru's, Toyotas, and Hondas. I have a 06CRV that I have run 5w20 Moblie one with the pricey Fram oil filters since new and the CRV has over 180k miles on it. It burns no oil, and leaks no oil, and it is quiet. My parents use 10w30 in Toyotas of all kiinds and get over 300K miles with them.
#51 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
While the xW20 oils will improve MPG, I am not sold on engine protection with that thin of an oil.
I think it is all about pushing for what is most "green" for the planet these days and I would use 0W30 well before 0W20 or 5W20. |
#52 | |
![]() ![]() Drives: 2008 yaris sedan Join Date: Jul 2010
I don't know If you got that Right my Friend??? factory fill level is above the full mark by a 1/4"+,I get my OIL change at a very trusted shop , they specialize in Toyota and other Imports,they fill it to spec 4 qt. and it comes to above the full mark 1/4''+, same thing at the dealer where I had my 1st oil change . Yes I know how to read a Dip Stick.? Last edited by krolos; 09-05-2010 at 08:53 AM. |
#53 |
FYI, for those of you that have Oreilly auto around you, they have an add today selling 5 qts of irelly full sythetic oil and a Wix filter for 19.99 good price!
The wife Highlander is due anyways! |
#54 | |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
| Yaris oil change appreciation | flagmunkey | DIY / Maintenance / Service | 18 | 07-19-2007 03:46 PM |
| first oil change? | wushumasterku | DIY / Maintenance / Service | 41 | 06-07-2006 10:32 AM |
