Old 01-27-2010, 04:39 AM   #235
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by yaris-me View Post
Sexy engine! You need a pink dip stick to set it off!
OR >>> Garm's Intake Mainfold
I'm waiting . . .
BTW just found this on my pc > http://www.youtube.com/watch?v=u0wage2LBdM
Parmas is offline   Reply With Quote
Old 02-12-2010, 11:27 AM   #236
Parmas
Parmas's Avatar
This week we installed Siemens Deka 4 630cc injectors. Since the Siemens housing length is slightly different from original toyota injectors they needed to be "modified" to match the fuel rail.
Now needs tuning from scratch, I hope it makes real power with these on
Old 02-12-2010, 12:37 PM   #237
ooh man can't wait for new results!! I have great hopes for this project!
Old 02-12-2010, 02:51 PM   #238
Parmas
Parmas's Avatar
My tuner just called in to tell that tomorrow will trial the car for some drag races. I am expecting 16psi or more boost with better AFR numbers than the previous tune.
Guess what? ..... if all goes well I think I will be the one to trial the Gude Performance Head package on our 1NZ. I already send him an e-mail to get some more details on cams....
Stay tuned!
Old 02-12-2010, 06:29 PM   #239
You're drag racing tomorrow? or tuning tomorrow, or both... ?
Old 02-13-2010, 01:29 AM   #240
Parmas
Parmas's Avatar
Both :) Since we tune specifically on drag road for a precise and realtime tuning...
Old 02-13-2010, 02:27 AM   #241
oh "street tuning", gotcha.
Old 02-28-2010, 03:38 AM   #242
Parmas
Parmas's Avatar
Some bad news....
Yesterday we done a compression test since we are still having trouble idle and slow runing the engine. Well it result that 2 cyclinders are loosing compression and probably some valves not sealing properly...
There is also a problem to convert the engine with the authorities (due to some changes in law) since there is a fine difference due to bigger displacement (probably within $2000 range ) So we are now intending to modify the 2NZFE 1.3L engine block to match the 1NZFE rods and in the meantime solving aswell the problem of the compression. We have to measure all the necessary points of the block in order to make this happen....
This will cost lots of money & time and since I am out of cash it will be a while to update my status....
Old 02-28-2010, 11:28 AM   #243
aw, so sorry to hear this. Do you think the motor came to you with these problems?
Is this your first compression test on it???
Old 02-28-2010, 12:51 PM   #244
Parmas
Parmas's Avatar
It was checked the compression after we opened it to check all things right and found loosing. The problem should have been solved by then but it seems that it isn't infact.
I am thinking of making a 2NZFE block conversion to match the 1NZFE rods. Since the 2 blocks have the same bore size of 75mm, what issues (if there are) I could face doing this? Is there something I need to know before I get into it or else is it possible to make it without much complications?
Old 02-28-2010, 05:06 PM   #245
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
Garm... and can assure you and Parma, that the motor had excellect compression when we sold it.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 03-03-2010, 03:30 AM   #246
Parmas
Parmas's Avatar
I am not saying that the engine was defective when sold.
When the engine arrived, it was opened and checked that all parts match the details. After assembling a compression test was made and marked loosing. The mech said they solved it and I continued to finally tune in. When we noticed having several idle and slow running problems we checked again to be sure and found loosing again.
I think there is a funny thing around and someone fu**ed me from behind on this
Old 03-03-2010, 09:44 AM   #247
cdydjded
Drives: Yaris LB Turbo
A proper test that would have determined the condition of this engine is not a compression test, its a leak down test. A compression test only tells you the compression psi in the cylinder chamber but it does not telling you if the piston rings or valves are sealing correctly. BTW how much vacuum was you boost guage reading at idle?
Old 03-03-2010, 11:28 AM   #248
Parmas
Parmas's Avatar
Vacuum was -20 if I remember correctly.
Tell me more about this leak down test
Old 03-03-2010, 01:00 PM   #249
cdydjded
Here is a good article:
http://www.carcraft.com/techarticles...ter/index.html
My car is @ -22 so -20 is not that different. You low compression issue could be one of the following problems:
Piston ring end gap wrong
Piston to cylinder wall clearance wrong
Valve to valve seat problem
Crack or broken ring lands
These are just a few that I can list. Im not saying it has to be one of these, but its a possibility.
Old 03-03-2010, 03:27 PM   #250
Parmas
Parmas's Avatar
Nice test I didn't know about it since now. Interesting tool ... what brand do you recommend?
Old 03-03-2010, 05:07 PM   #251
cdydjded
I dont have a specific prefrence, here are a few:
http://www.google.com/products?hl=en...ell=1&oi=spell
Old 03-03-2010, 05:10 PM   #252
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
If you have a compression tester, you can easily tell if it's the rings or the valves which are causing the problem. Run the compression test as you would normally and take note of the reading.
Then remove the compression tester fitting and drop a teaspoon of oil (any normal mineral oil will do, castor oil, motor oil, doesn't really matter as long as it is thin (ie. not gearbox oil)) down the spark plug hole and then repeat the compression test. The oil you put down the combustion chamber helps the rings to seal better. If the reading is the same as before the oil was added, then the problem is in the head (valves, valve guides etc). If the reading is dramatically better than without the oil, then you look towards your pistons and rings for the problem.
If the reading is only slightly better than before you added the oil, but still low compared to the other pistons, then you possibly have a bent rod.
rob323 is offline   Reply With Quote
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
