![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
W.O.T in neutral
Firstly, let me state that I have seen zero in the way of actual evidence that any Toyota has truly experienced spontaneous acceleration and am maintaining the view that what we are observing is mainly a demonstration of a (very interesting) mass-psychology/media/political phenomenon.
However, there has been much talk about throwing the car into neutral with the throttle wide open. Most of my experience is with old technologies where the result would be immediate engine failure due to excessive RPMs. Thrown rods, I would guess. What, exactly, would happen with the Yaris in this case? I assume there is some sort of governor. How fast would the ECU let the engine turn? -Steve P.S. I should probably say the obvious: Don't try this at home. |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Sooner or later it'll run out of gas..
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
It would bang the rev limiter at about 6200 rpm.
Some cars have a secondary rev limit that kicks in at a lower rpm in some conditions. (like my old Saturn limited to 4k if the car wasn't moving) Not sure about the Yaris. Modern engines are designed to basically not harm themselves. You can bang the rev limit for quite some time without hurting anything. Now, if you botch a shift and do something like grab 2nd gear when you were reaching for 4th after revving out 3rd... that can over-rev and do some damage. (if you have an automatic, the ECU won't allow such a downshift, it will delay the downshift it until it is safe) Wanna see what your Yaris will do if you drop it into neutral at speed and keep the hammer down? Try it! Seriously, you're not going to hurt a thing, just make a lot of noise and scare pedestrians. If you actually HAD a stuck throttle, you'd probably want to kill the ignition when you went to neutral and just be aware that your power brakes are going to go away very quickly due to no vacuum. (you can still stop, it will just take more pedal effort) |
Half a Bubble Off Plumb
The fuel injection cuts off when it hits the maximum allowable revs. About 6200 for the 1NZ-FE.
You can still blow one up overreving if you have a manual transmission and downshift too far at too high a speed. |
![]() ![]() Drives: 2010 Black 3dr Hatch Join Date: Nov 2009
I tried it the other day (due to a separate post on this forum) coming out of 1st going into 2nd I pushed the clutch in at 5500 RPM at wot and.....
nothing spectacular happened, the engine just screamed for a second or 2 and the fun was over
Thanks for the very informative responses. Even though my field is computer science, I do sometimes find my intuition to be a bit anachronistic in today's Brave New World. All those old rules of thumb require constant reevaluation and culling. ;-)
In my 1988 Chevy Sprint 1.0L w/5-spd manual, I've always had a policy of limiting it to a maximum of 3300 rpm, and really trying to keep it below 3000 rpm. I'm sure that's over-pampering. But higher RPMs give me anxiety. My Yaris' automatic transmission and cruise control conspire to allow much higher revs. I suppose it is something I'll eventually get used to. In case anyone is interested, that works out to a maximum theoretical top speed of 146 mph for an automatic Yaris with 185/60/R15 tires. Assuming there were enough actual power to manage it. -Steve |
yaris fuel cut is about 6500 rpm or so...it'd just bang off the rev limiter if you toss it in neutral and hit the gas
as a point in fact, ive revved my car in anger while in neutral and banged it off the rev limiter... in this exhaust vid i made too.... ![]() *edit: to the OP, if you don't like to drive a car over 3300rpm, never buy a car w/ a b16, b18, k20 or 2zzge in it, lol, you'll be wasting your money
#8 | |
-Steve |
true. i grew up w/ v6's, but the first car i modded had a 2zzge in it....so max power was at/around 7800rpm....made power to the fuel cut at 8350. it started making power where the yaris redlines...
#11 | |
oh man... think about those rotaries that drive over 10k rpm :)
#13 | |
-Steve |
#14 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Congress only called the Toyota CEO in to destroy his company, to make the taxpayer investment in G.M. more valuable. 51 deaths by predominantly people over 60 hitting the gas too hard, is hardly newsworthy in usual circumstances. It would look bad on the congress members who put so much money into GM, if they didn't make a profit, so they destroy the competitor.
The main profiteer of the cash-for-clunkers program was Toyota with Corollas selling like eight balls of cocaine. That's not what congress wanted. |
#15 |
I honestly think that this smear campaign would have been launched even if the US Federal Government were *not* part owners of GM and Chrysler. The fact of the matter is that Toyota and Honda crushed our American auto industry by producing better products at a better price. And that could not be allowed to go unpunished under any circumstances. The United States of America is the Greatest, Most Free, and Best Nation On Earth. And beating us fair and square in a free market is inexcusably *Unpatriotic* of those Japanese manufacturers.
-Steve |
#16 | |
Anyways... it always depends on the car. A Smart CDI, you'd keep it between 2000-2500rpm with a redline at 3200rpm! A rotary engine is to be kept above 6000rpm... A honda should be kept above 3000rpm... American muscle don't rev very high, so you don't drive it the way you drive a japanese car. When was the last time you saw a japanese car that stay at 1500rpm @60mph ? As you are talking about your chevy sprint... I had the original suzuki swift. That thing ran at 3500rpm @60mph!!!
#17 | |
The 5 speed manual Sprints had a 0.76:1 overdrive. And the Sprint Metro had a special 3.79:1 final drive, in addition to a low lift, short duration economy cam, different ECU, and special low friction piston ring configuration. With P15580R12 tires (3% larger diameter than the original, and impossible to find, P14580R12 tires) my Sprint Metro turns 2660 rpm at 60 mph. On teamswift, those who have changed their ring and pinions out for the 3.62:1 variety available on certain 1.3 liter 4 cylinder Swifts tend to chide the rest of us with their 2550rpm@60mph readings. (Some members even lie about their FD.) The Yaris, in 4th gear, turns about the same speed, about 2550 rpm, at 60 mph. Its comparatively huge, monster inline 4 1.5L engine allows for that. ;-) -Steve Last edited by sbergman27; 04-12-2010 at 09:09 PM. |
#18 |
| Coasting in neutral | bankrobber | Fuel Economy Forum | 9 | 03-11-2010 03:55 PM |
| Fan setting to neutral (not hot or cold) defog? | PhasedWalker | Fuel Economy Forum | 3 | 07-19-2009 01:21 PM |
| Deficit Neutral? | yaris-me | Off-topic / Other Cars / Everything else Discussions | 0 | 07-08-2009 12:08 PM |
| Shifting into neutral | otterhere | Fuel Economy Forum | 24 | 01-17-2009 02:46 PM |
| Park, rear, neutral, drvie, 3,2,1 thingy | BMGYaris | Cosmetic Modifications (Exterior/Interior) | 7 | 05-11-2007 11:06 AM |
