I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
ok, so where the hell do I ground my amp??
I am in the middle of my amp install and I have ran my power cable, but I cant see any convenient place to to screw the ground wire to the chassis. The 4 bolts that hold on the plastic panels are screwed into rubber and the bolts that hold the seats down are some weird bolt i don't have a tool for. Do i make my own screw hole in a random place and screw it down? how do i avoid damaging something important?
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#2 | |
Audio Junky
Make sure when you do find a convenient location to scrape the paint off, you want bare metal to make good contact, and a good ground. I was surprised at how the battery was grounded to a painted area, Nice engineering.
While you're there working on that wire, i'd reground the battery and scrape that paint off of where the battery grounds to the chassis, It's a quick and easy fix and will deff help with the lights not dimming. And what you'd probably be looking for to connect to that seat belt bolt is a copper ring terminal, You can either solder it onto the wire or take a hammer to it, them things are pretty tough so if you want to crimp it make sure your wire crimper has long handles. I picked some up at my local Ace Hardware for around a buck.
#4 | |
USAF_SrA_E-4
I had my amp ground in the trunk
#5 | |
Audio Junky
Same here with beating them on the cement, them things are bullet proof, then just wrap the back part with some electrical tape and presto you're good to go . ( I like to put a lighter to the electrical tape after wrapping just so it'll stick better. )
Note: Make sure to note if you need any ring terminals on the power wire and get them on before you install it that way you aren't done and ready to connect everything and then you're like damn, How the hell am i going to crimp these things.
I just man connectors on wires... with my fingers... :P
After the bleeding stops I break down and get channel locks lol
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
I ♥ Yaris
Ok... I searched everywhere, a hardware store, 3 car part stores, a stereo install place, and best buy, and I cannot find a 4 gauge loop terminal that will fit the bolt in my seat belt mount... I'm about to solder a few loops of bare copper wire onto the end of the ground cable...
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
Try a welding supply store. I have bought some copper ones there before that were large enough to drill out the hole big enough for a seat bolt.
I had trouble as well, smaller places like Ace if not a locally owned hardware shop will have them in the welding section. Try finding 0 or 4 gauge spades, that's even more fun.
| How to ground my Amp on Yaris Hatchback | charleschia1986 | In Car Entertainment + Electronics (audio / video / alarm) | 35 | 11-20-2009 03:13 PM |
| Amp And Cable Kit Question | Kaotic Lazagna | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 01-28-2009 06:59 PM |
| Quick advice needed on unfinished amp install | GreenSpeed | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 01-15-2009 11:03 PM |
| Connect mono amp. + subwoofer to stock HU? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 10-28-2008 10:01 PM |
| Help with Amp Ground in Trunk | Meldav86 | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 03-22-2007 01:31 PM |
