![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
tpms
I've looked and tried to find the answer before asking:
Is there a DIY way to have the car's ECU re-learn a new set of TPMS without having to go somewhere and have it done?
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
I only remember seeing a DYI disable for them.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
The TPWS can only learn new sensors with the use of a service tool. Most tire shops (and of course dealers can do it).
Do you happen to know what the service tool is? My fiance has a crap load of tools from when he used to work as a mechanic, so it's possible he has it already. That's the main reason I asked.
Not a mechanical tool, but an electronic one - Either the Toyota TechStream tool or a TPMS diagnostic tool.
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback Join Date: Jan 2010
ok honest question here.... does it matter if you dont use your sensors at all on aftermarket wheels?
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
Does it matter? To a Federal Bureaucrat it matters. To me, ..... I just disabled the TPMS and have no sensors at all in my aftermarket summer wheels. My winter wheels still have them but they are just useless rotating mass now.
Half a Bubble Off Plumb
If it doesn't bother you to have that low tire pressure warning light constantly lit, and you'll keep your tire pressure checked regularly, it's no biggie.
Chunk love Yarii
well then i dont really care....... i take good care of my vehicle
I don't like having the TPMS as it is. But wouldn't it be cool if it would give you a readout of the actual pressure in each tire?
I love momentum.
So far as I know, every time you change wheels (if going between winter/summer), you have to pay to have the TPMS re-calibrated. And because of that I simply disabled mine. I check my tires pressures regularly, I don't need a (generally useless) electronic babysitter.
tirerack.com sells the ATEQ TPM QuickSet Reset Tool for $135. luck123@toyotanation has a review of it
http://www.toyotanation.com/forum/sh...d.php?t=299107 http://www.tirerack.com/accessories/detail.jsp?ID=163 |
It would - They report pressure and temperature, so it would be very cool to have a live display of both for each tire. One of these days I'll figure out the protocol for the Yaris TPWS and make a device to do so. Crashy will be my test platform, since she has my 09 steelies with the sensors. Both of my sets of alloys that I run on my 09 are sensor free.
#14 |
Hmmm sounds suspiciously like mirror mounted turn signals...
#15 |
![]() Drives: 09 Flint Mica Sedan Join Date: Feb 2010
how did you disable your TPMS? I'm looking for a solution to end once and for all the constant tire pressure light. I didnt get the sensors installed on my after market rims..and don't want to deal with the light anymore
#16 | |
Jump right to post #115 |
#17 | |
i read your original post then the pg 3 info w/ all the parts from radio shack...post 115 just looks like the brown wire was cut and tied to the white wire #6. is this correct? and if so, what did you use to connect the brown and white wires? |
#18 | |
You are correct with simply cutting the brown and connecting it to the white. You can use a simple tap splice connector to do it (available from any autoparts store). |
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 02:00 PM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 09:33 AM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 12:18 AM |
| 15" TPMS friendly wheels for my '08. Ideas? | auxmike | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 12-08-2008 08:01 PM |
| TPMS | TinyGiant | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-22-2008 03:57 PM |
