Old 10-28-2009, 04:59 PM   #1
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Stripped Bolts
So I finally got a wrench that actually worked, and the only two bolts left to do are the ones I stripped yesterday. I'm going to give them one last try, but how do I get them out if they are completely stripped?
Oh, and another question, I can't seen to figure out how to get the top of the seatbelts out. I don't want to push too hard on the plastic, because I don't want to break it. Is there some trick I don't know, or is it simple pressure?
Colin Chapman disciple
Old 10-28-2009, 05:16 PM   #2
bronsin
bronsin's Avatar
Get a wrench made by Snap On in the size that fits. They will work on the heads of nuts/bolts even if they are totally rounded off.
Old 10-28-2009, 05:25 PM   #3
linny
Drives: '08 liftback mt
Use a dremel tool to turn the cap head into a slot head and use a big screwdriver.
linny is offline   Reply With Quote
Old 10-28-2009, 05:45 PM   #4
severous01
cutoff-wheel, chisel, ez out? or, you can head to autozone and pick up a set of irwin extractors for about 20 bux. not bad seeing as how the snapon set which is made by the same company is almost 200.
Old 03-30-2010, 09:21 PM   #5
captaincrunch
Chris
captaincrunch's Avatar
I'm not sure what size. I just got done looking at it a few hours ago. I know there is a set you can get at sears or advance auto parts called bolt out. I'm going give it a try and let you know if it helps.
captaincrunch is offline   Reply With Quote
Old 03-31-2010, 04:44 PM   #6
captaincrunch
Chris
I was wondering some cars had reverse thread. Do you know if that is the case?
Old 03-31-2010, 05:10 PM   #7
severous01
well, the easy thing would be vise grips for me depending on where they are and how big...anything up to about 15mm
or, drill and extract w ez-out, slot and use a freakin massive screwdriver...use a chisel and tap in reverse direction, like you're trying to back it out with the chisel...
sometimes you can just hit it really hard in the center with a punch and it makes things easier to back them out.
but like mentioned above, use a high quality 6-point wrench or socket made by snapon mac or matco. they have what's called flank-drive. it's set up to touch on the flats of the bolt, not the edges like cheapo wrenches and even craftsman.
Old 04-03-2010, 07:34 PM   #8
captaincrunch
Chris
Yes..I just use the bolt out and it works really well. I think the bolt however messed up the some of the threads though. I'm going to try a shorter bolt and see if it works, but new belt is on.
Old 04-05-2010, 01:15 PM   #9
severous01
reverse threads are usually only used on waterpumps. or fan clutches. i can't really think of any other application where one is used on a car.
Tighten bolts to factory specs? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 10-19-2010 05:18 PM
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
Front Camber Bolts lilredrocket Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-23-2009 11:57 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
Trouble removing stock HU bolts The Spectacle In Car Entertainment + Electronics (audio / video / alarm) 8 10-28-2008 09:58 PM
