Old 04-07-2010, 04:24 AM   #1
Stiv
Drives: Yaris TS 1,8L
Speedometer calibration
Just the other day there was 5th Gear on Discovery channel. There was a guy attempting to do a big loop. Long story short: http://my107.blogspot.com/2009/05/fi...aygo-loop.html
And so, in preparation for this stunt, the guy needed to calibrate his speedometer. And he did. But how?
I went from 205/45 17 to 205/45 16. And sure, my speed is a bit off now. It doesn't bother me that much, but if calibration is possible, I'd like to do it.
Any info on that?
Stiv is offline   Reply With Quote
Old 04-07-2010, 01:41 PM   #2
There's not a way that I am aware of. The microcontroller in the speedometer receives a pulsed signal from the speed sensor. Theoretically, one could adjust the code that translates the pulses into speed to adjust for wheel diameter differences, but there is not a parameter tweakable by the Toyota service tool to do so. Considering that he had one critical speed that he needed to maintain, he probably just calibrated for that particular speed (i.e. used a highly accurate system to compare the visual speed on the speedometer to the "real" speed that he needed to maintain.
Old 04-20-2020, 09:54 PM   #3
blktiger60
blktiger60's Avatar
Drives: `08 HB S
So if you run something other than what the car was engineered to run your speedometer will not display accurate info, including an effect on your odometer.
My '08 3 door S came with 185/60/15's.
I run 215/40/17's in the summer, almost an exact match with the 215 .1" bigger.
For winter tires the choice is more difficult. I'm replacing 2 this summer. From my experience skinny is better, in both mud and snow.
I'm thinking about https://www.discounttire.com/buy-tir...nter-studdable 175/65/15, .3 bigger dia.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
speedometer lights pEAchEzpwnz DIY / Maintenance / Service 8 04-20-2020 10:02 PM
speedometer from TS in terra mk1 tiger Cosmetic Modifications (Exterior/Interior) 0 09-02-2009 02:15 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 11:38 AM
Speedometer Error? MadMax General Yaris / Vitz Discussion 18 02-27-2009 08:22 PM
Changing out the stock speedometer and getting a digital daf62757 Fuel Economy Forum 2 02-21-2009 12:21 AM
