Old 04-10-2010, 11:36 AM   #19
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Hey guys,
With the help of Bobolinko, I think I've come up with the easiest method and least invasive. Please see the attached pictures.
The resistor used is a 10Kohms resistor (Brown - Black - Orange - Gold/Silver). It took only 5 minutes to put together (10 if you count the time sifting through a bag of resistors to find the right one ).
With the right hand side unused headlight plug facing you, insert one spade connector into the right side of the plug and the other spade connector in the top-middle of the plug.
Thanks Bobolinko for all your help and speedy responses! Greatly appreciated! I'm sure I'm not the only one who will be greatful either. Goodluck everyone and enjoy your high beam indicator!
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 05-14-2010, 04:01 PM   #20
joeljcruz86
Little Eggy
joeljcruz86's Avatar
Drives: Toyota Yaris Liftback 3DR 2009
Send a message via AIM to joeljcruz86
Originally Posted by bobolinko View Post
this is the simplest fix.
I used the right side (unused) Original Headlight socket to make these connections.
50 cents and done in a jiffy. If you want to make it "professional" looking. buy a connector from Radio Shack and fabricate the wiring on that, and plug it into the old harness.
-I have the same problem but I don't understand what I am suppose to do with my leftover stock harness with this diagram.
joeljcruz86 is offline   Reply With Quote
Old 07-08-2010, 06:22 PM   #21
joeljcruz86
Little Eggy
I have a problem with my HID's. For the first 2 months since i've had them, they were working fine until now. They only come on when i have a normal headlight bulb plugged into the leftover/passenger side harness. I don't know why this is happening. I was thinking of using a wire with a 10k ohm 1/4watt resistor in the middle to plug into the to top hole on one end and the other to the right hole of the left over harness. This method i found on one of the forums is for to get the high beam light to show in the guage cluster. I'm hoping that this method would substitute the "normal headlight bulb" to get the HID's to be working as well.
If anybody has any solution and knows for a fact that any of the methods is not going to work, PLEASE LET ME KNOW!! THANK YOU.
Old 07-24-2010, 05:50 PM   #22
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
a buck for 6x 10k resistor and just slipped it in at the back of the socket..my hid is running on both side with individual relay kit.
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
Hi & Lo Beam HID Conversion Kit OgDogg Items for Sale by private party 0 11-11-2008 04:55 PM
