Old 04-17-2010, 06:33 AM   #1
Toy Yaris
Drives: 2nzfe 3dr Yaris
rear exhaust heat shield
hi guys/gals wondering i got a rattle from the rear exhaust heat shield, is it safe to remove it or can I use some in between the exhaust and heat shield? tried bending it but it's pretty firm against the body as it is any ideas??
oh btw it's not a stock rear muffler.
thanks
Toy Yaris is offline   Reply With Quote
Old 04-17-2010, 10:33 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
The problem with not having a heat shield is when you're stationary. The heat rising from a hot muffler can damage the paint over time, not to mention heating up the inside of the car. Can't you fix the rattle without sticking something between your muffler and heat shield?
Old 04-18-2010, 01:00 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
Do you have a picture of this heat shield? I just looked at mine and don't see anything b/w the exhaust and the underside of the bumper right above the exhaust.
Old 04-18-2010, 05:11 AM   #4
Toy Yaris
Tried bending it but it's as far as it can go it only vibrates when the road gets a bit rough but still drives me nuts
Old 04-18-2010, 05:27 AM   #5
Toy Yaris
here is the pic of the heat shield I had to move the muffler to the side so you can see.
Old 04-18-2010, 09:57 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Are you sure the muffler itself isn't rubbing it, causing the problem?
Old 04-18-2010, 10:54 AM   #7
nemelek
DWEED
nemelek's Avatar
As cars get older, I get a louder sound system.
Old 04-19-2010, 06:03 AM   #8
Toy Yaris
Yeah the muffler is hitting the heat shield, might try new rubber hangers
question on Rear Hub Spacers mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-02-2010 09:54 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
