Old 12-23-2008, 01:37 AM   #1
DIY Thai Vios Sports Grill
It's been a while since I installed it, so I'm going to try to remember everything step by step. Sorry in advance if I forget something. Here it goes (stupid hackers):
I forgot how long it took to install, but I just remember it longer than it should have since I ended up cutting myself.
Tools needed:
- Philips screw driver
- Box knife
- Dremel (will make it easier, I didn't use one tho since I didn't have one)
- Water (might get dehydrated)
- Ratchet wrench with (I forget what size sockets)
Before:
Step one:
Jack the front of the car up. Unbolt these bolts from the bumper in the wheel-wells.
Step two:
Remove these pop-in/suicide screws (what ever they're called) from the top of the bumper. I used a thin flat head and gently pried them off in a circular fashion.
Step three:
*Read text in pic*
Step four:
*Read text in pic*
Step five:
*Read text in pic*
Not a step, but just showing the damage that the concrete block on the freeway caused:
Showing the locations of the clips (except the side clips)
...continue...
Old 12-23-2008, 01:42 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
Thanks i have my grill thats been sitting in my garage for the longest time. Nows some motivation go go out and install it hehe
Old 12-23-2008, 01:57 AM   #3
Step six:
*Read text in pic*
Step seven:
*Read text in pic*
Step eight:
Gently remove stock grill off of the bumper.
Comparison pics:
*Top is the mesh, bottom is the OEM one*
*Also note how the mesh grill doesn't have the screw mounts that the OEM one has*
Old 12-23-2008, 02:07 AM   #4
Step nine & 10:
I shave down the tabs on the mesh grill since they were waaaay toooo big to fit in the slots. I also made some of the slots bigger to accommodate the tabs. I used a box knife to do all of this, but I think a dremel will work wonders on the tab. Using some force/coercing, push the tabs into the slots.
*****************IF YOU'RE USING A BOX KNIFE OR SOMETHING SIMILAR, BE REALLY CAREFUL. I cut my thumb in the process, and that took some time to clean up and bandage off.***************
Showing the trimming on the tabs and the slots.
Be careful to not too much force, or else the tab might snap.
It started to rain a little (and started to get dark), so...
Old 12-23-2008, 02:12 AM   #5
Step 11:
*Read the text in the pic*
Step 12 & 13:
Put the bumper back on, and screw in all the screws, and push in the pop-in screws. If you have foglights, plug them back in before you put the bumper back in. *I was pressured in time, so I didn't take pics of this*
Step 14:
Step back and look at the difference it makes.
Old 12-23-2008, 02:13 AM   #6
Old 12-23-2008, 03:29 AM   #7
wheee thanks for putting this back dude
Old 12-25-2008, 11:17 PM   #8
No problem. Has it been added to the compilation of DIY's?
Old 01-05-2009, 07:27 AM   #9
FcukThis
Drives: yaris
Hey jw, Does garm still sell these grills ?
Tried looking on the website for them, but they weren't on there.
did i miss out? :\
FcukThis is offline   Reply With Quote
Old 01-05-2009, 08:02 AM   #10
did i miss out? :\
Who's JW?
You should PM Garm to see if he still has any in stock. It's worth the money.
Old 01-21-2009, 11:50 PM   #11
Pitt Yaris
Drives: Flint Mica Sedan
did you buy it pre-painted?
Old 01-22-2009, 12:16 AM   #12
hafeez
Drives: 2007 Silver Toyota Yaris Sedan
where can i get one of these grilles?
hafeez is offline   Reply With Quote
Old 01-22-2009, 01:13 AM   #13
No I did not. I had it professionally painted. Next time I get a mod like this, I'm painting it myself. hehe.
Old 01-22-2009, 01:16 AM   #14
Contact Garm (Cali Yaris) to see if he has any more sports grill in stock. http://www.yarisworld.com/forums/forumdisplay.php?f=56
Old 06-11-2009, 06:12 AM   #15
yurishi zu
yurishi zu's Avatar
Drives: Yaris S 2008
Send a message via MSN to yurishi zu Send a message via Yahoo to yurishi zu
Grille
Just wondering where and how much you got your grille
yurishi zu is offline   Reply With Quote
Old 04-19-2010, 07:05 PM   #16
kaiksemh
Drives: toyota yaris sedan 07'
i bought one of those mesh grills from microimage which i paited it myself, my yaris color is flint mica and i painted the grill black and chrome, not bad!!!! i'll post some pictures.
kaiksemh is offline   Reply With Quote
Old 04-19-2010, 07:08 PM   #17
kaiksemh
and having trouble installing the grill, this post will help me alot.
thanks kaotic lazagna!!!!!
New grille or not free297 Cosmetic Modifications (Exterior/Interior) 27 11-14-2010 03:21 AM
DIY: Yaris Hatch grill block/air dam yarswiss DIY / Maintenance / Service 0 10-26-2008 06:52 PM
Vios Grill Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 32 09-23-2007 01:14 AM
