![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Can anyone tell me if the alternator pulley from a Scion xA/xB will fit on the Yaris alternator? It seems they take different alts, but I'm wondering if the pulleys are the same.
NST sells an overdrive pulley for the xA/xB, which has the same belt size and offset as the Yaris, so I'm wondering if it would work on the Yaris alternator? |
Nevermind...just got word back from NST that the center bore size is different between the xA/xB and the Yaris. At least now I have a definite answer.
Has anyone had luck finding an overdrive alternator pulley for the OEM Yaris alt? |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
Out of curiosity...what exactly will that accomplish? More power output from the alt?
Supposedly, higher/more consistent output when the engine is idle/at low RPM
If anyone's interested, I was able to custom order a 20% overdrive alternator pulley from Mike at NST.
Combined with a 10% underdrive crank pulley, the 20% overdrive alt pulley should get me a 10% gain on the alt. The way he and I figured it, using a 10% overdrive alt pulley & 10% underdrive crank pulley would've been pointless, as the two would cancel each other out and I'd end up in the same place I'm at now. I'll have a definite answer in 5-6 weeks. |
#6 | |
#1 Lemming
Sounds like a simple and cost effective mod, as long as the results are effective anyways.
#7 | |
I'm hoping this overdrive pulley will allow for a higher/more consistent voltage output at idle/lower RPM. |
Learn to Relax
You have a lot to learn.
#10 | |
Learn to Relax
![]() That being said, the xB has a larger alternator for increased output for audio upgrades. That was anticipated because it is geared for the youth market.
#11 | ||
If I turn everything back on, the voltage dips even lower for a second, then stabilizes back around 13.4 - it never increases anywhere near 14.1 at idle, regardless of load. |
#12 | |
Learn to Relax
| Transmission Question | CMR | General Yaris / Vitz Discussion | 42 | 04-14-2010 12:38 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| So question here abt hatchs in general | Jem_hadar | General Yaris / Vitz Discussion | 12 | 01-06-2009 03:06 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
