Blazing Blue Yaris
AFE Intake cel
Recently installed an AFE intake. CEL came on after about 100 miles. Disconnected battery and cel went away for another 100 miles. Had code checked and came up with p0101 MAF sensor failure. Codes were cleared then cel came back on after about 30 miles. Have checked previous posts. Not many have posted if they fixed this.Any suggestions? Hoses are tight and the MAF is tight and appears to be seated properly.
![]() ![]() http://www.yariscentral.com/index.php Just an old guy rockin it with you young-uns |
Mr. 155 and climbing
possible that you damaged the MAF sensor during the installation? Have you tried the DIY on how to clean the MAF sensor?
Blazing Blue Yaris
I was extremely careful with maf and it looks clean
![]() Drives: Yaris Sedan 2008 Join Date: Oct 2008
I am having a same problem did you fix it yet?
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
spray it w/ maf cleaner
Blazing Blue Yaris
The problem I was having was caused by the spacers under the MAF sensor. I installed the MAF without the spacers and that cured the problem. You just have to be very careful and not over tighten the screws.
Mine does'nt have a spacer to begin with, even w/ the stock intake.
Blazing Blue Yaris
AFE supplies spacers to put under the maf screws to prevent people from over tightening them and pulling the threaded inserts out of the intake
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
did you use the foam seal on the maf that came with the kit? you may want to get some 1/4" thick foam and cut a new gasket. my bolts came out (the nut part in the plastic came loose). i have to zip tie my maf down against the seal.
Blazing Blue Yaris
yes I used afe's foam gasket. I called the factory and talked to them. Removing the spacers was their suggestion. You have to be very careful not to over tighten the screws
What I found is the screws that they supplied was too long. I replaced the shorter screws and took out the spacers for a week now. It does not find P0101 any more. Thanks rihdrkc.
![]() Drives: 2012 Yaris SE Five Door Join Date: Dec 2011
aFe on a 12 SE
I just put the aFe intake on my 2012 SE. The heat shield fits OK-you just need to bend it a bit but it clears the hood, etc. Also, there is a vaccumm hose mount on my '12 that is not included in the aFe tube. I just zip tied it out of the way.
On topic, I got the P0101 CEL code and someone kindly pointed me to this thread. Glad YW forums are here! Great resource! ![]() /randy |
| AEM cold air intake vs Afe intake... | djgab101 | Performance Modifications | 69 | 04-28-2013 02:03 PM |
| AFE Intake and NST 10% UD Pulley Gray | hatchbackkid82 | Items for Sale by private party | 12 | 04-17-2010 09:16 PM |
| Garm's AFE intake vs. TRD high flow air filter???? | computerlove87 | Performance Modifications | 28 | 07-22-2009 05:05 PM |
| Afe intake installed...CEL ??? | vten | Performance Modifications | 7 | 06-05-2009 12:08 AM |
