Old 05-22-2010, 01:16 PM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Rostra cruise control issue
I need help with where to begin. The dealer installed rostra cruise kit shuts off intermittently and sometimes but not always, on bumps in the road. Dealer could'nt reproduce concern, obviously. Anyone, maybe CTScott lol, have any ideas on where to start? Im gonna look first at the. Connector ends to ensure they're tight. after that dunno what to check. Thanks in advance!!
Old 05-24-2010, 07:08 AM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
90% odds that its a loose connector somewhere.
If the dealer installed it, they should fix it.
Old 05-25-2010, 12:40 AM   #3
Shroomster
Shroomster's Avatar
If dealers actually cared about warranty work then it wouldn't be a problem....I'm trying to get the wife to let me take it in and get someone to drive it with me on the interstate, but she is closed-minded about giving up her car for more than a few hours let alone a day or so....
at any rate I actually was hoping someone might have the diagram handy of the wiring diagram for it.....if not I will check the company site for a possiblity....
Old 05-25-2010, 05:41 AM   #4
swidd
Drives: Yaris HB
I have a problem with the brake pedal stop light switch being too sensitive/ill adjusted, so when going over bumps, the brake lights turn on intermittently. That also turns off the cc when hitting bumps. You can drive at night and put a piece of paper in the rear window to make it easier to tell if your brake lights are on when they shouldn't be.
I fixed it by jammig a double sided piece of scotch tape on the tip of the stop light switch.
swidd is offline   Reply With Quote
Old 05-25-2010, 05:45 AM   #5
swidd
Drives: Yaris HB
Along the same idea, if yours is manual, check the tightness of the clutch switch. Since it is happening on bumps, it may be due to those pedals moving aRound sensitive switches.
Old 02-24-2011, 10:56 PM   #6
Shroomster
Shroomster's Avatar
UPDATE:::: Finally got a tech to test drive with me, confirmed that rostra cruise is now not working at all, stalk light comes on but cruise will not engage...FINALLY! 3 years of this issue.....I'll update with fix/repair when performed
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
A Sub 4 Rostra cruise control (am in Texas) elo79 Performance Modifications 9 12-19-2006 03:35 PM
