Old 05-29-2010, 08:53 PM   #1
castillo
Drives: Toyota Yaris 2007 4dr sedan
Rear Speakers
I have a 2007 yaris 4dr sedan and the rear speakers stopped working. Does anyone know what might have happened and what do I need to check/fix?
castillo is offline   Reply With Quote
Old 05-30-2010, 12:41 AM   #2
GeneralDon7
Drives: Yaris Sedan
Well, if you have someone like my gf, who drives your yaris, they may have blown the speakers. But more then likely I would say check the settings on your radio, someone may have set it to output to only the front speakers. I'm not sure if you have the integrated radio or the standard one, but for the integrated one you hit the right knob in to go through the settings.
GeneralDon7 is offline   Reply With Quote
Old 05-31-2010, 12:13 AM   #3
jtown
Drives: Yaris
Check the fader first, as suggested. If it's set correctly, you'll have to keep digging. If there's absolutely no sound, check the plug on the back of the stereo. The rear speakers are fed by their own plug. It may have worked loose and rear speakers are the only thing that would be lost if that plug came out.
jtown is offline   Reply With Quote
Old 05-31-2010, 12:51 PM   #4
castillo
I've checked the settings on the radio and the connector on the back and they're good. I thought maybe the stock radio had a problem so I installed an aftermarket radio I had laying around and the rear speakers still didn't produce any sound.
Old 05-31-2010, 01:02 PM   #5
yarrr
Drives: 07 sedan
did you check the connections in the trunk, under the actual speaker? I've knocked both loose at once before
yarrr is offline   Reply With Quote
Old 05-31-2010, 11:08 PM   #6
castillo
yes, I've checked that too. What are the chances that both rear speakers would blow out?
Old 05-31-2010, 11:22 PM   #7
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
unplug the stock cables to the speakers, wire with some extra cables you may have around and connect to a 9v battery if they pop they should be good.. might be a problem in the wiring somewhere..
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Is worth it to replace only front and rear speakers? tealio In Car Entertainment + Electronics (audio / video / alarm) 35 04-16-2010 10:11 PM
Call to those who adapted 6.5" speakers to rear of Liftback W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 9 03-10-2009 11:06 PM
Help needed! Fitting rear Yaris Speakers ovalbuster In Car Entertainment + Electronics (audio / video / alarm) 4 06-28-2007 01:29 AM
rear speakers not loud at all? davembfan General Yaris / Vitz Discussion 16 06-20-2007 03:29 AM
