Old 05-31-2010, 06:07 PM   #1
YenOfIrrelevent
GreenRanger
Drives: 08 Yaris sedan
DC Sports 4-1 Header vs. DC Sports 4-2-1 header
Hello I am trying to decide which header I should get. So far I know DC sports is very reliable but I see these different types of headers and I do not know which is best.
The choices are:
DC Sports 4-1 header (Ceramic or Stainless steel)
DC Sports 4-2-1 header (ceramic)
what is the difference in performance? Also does it matter if its ceramic or stainless steel?
I hope someone can help me out on this one... Thanks
YenOfIrrelevent is offline   Reply With Quote
Old 06-02-2010, 10:26 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
OBX makes a 4-2-1 for the Echo/xA/xB, but don't know if they made one for the Yaris.
Old 06-02-2010, 11:04 AM   #3
severous01
stainless is always good, and i think it's better than ceramic cuz it wont chip crack or peel.
other than that they're all the same
one thing, the 4-2-1 may add a little more torque but you'll lose high end HP, and vise-versa for the 4-1
Old 08-09-2010, 12:17 AM   #4
darkMINI
Drives: 08 hatch
Has anyone installed a DC header? Is it something I can do in the driveway on jack stands, or does it have to be done by a professional? Do you have to modify the stock exhaust system?
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 08-09-2010, 12:47 AM   #5
Brian
Brian's Avatar
You can do it in your driveway. Jack stands or ramps are recommended. It took me about an hour do install mine. It's a direct bolt-on so no modifications are required. I suggest some new gaskets while your at it.
Old 08-09-2010, 01:22 AM   #6
+1 direct bolt-on.
Some of the bolts are a little tough to reach, but otherwise, it's not that difficult.
In stock, too.
Old 08-09-2010, 01:33 AM   #7
kou
Drives: 08 lb
weapon r header 4-2-1 stainless steel.
Old 08-09-2010, 07:22 PM   #8
darkMINI
Drives: 08 hatch
I've heard that 4-2-1 is better for mid-range as well. Hows that Megan racing header?
Old 08-09-2010, 09:18 PM   #9
I used the Megan on my car before boosting it, was totally happy with it.
Old 08-10-2010, 12:10 AM   #10
darkMINI
Drives: 08 hatch
Thanks Cali, trying to keep cost down so's I can do a CAI, high flow cat, and muffler at the same time. Reaching for 100 HP.
Old 05-09-2012, 06:09 AM   #11
allyart
allyart's Avatar
Drives: Yaris Hatchback E A/T 2011
from what i know is that the 4-1 will give more power on the low rpm (easier acceleration) where the 4-2-1 will give more on high rpm (easier top speed)
-cmiiw-
allyart is offline   Reply With Quote
Old 05-09-2012, 09:38 AM   #12
OLD thread!
DC Sports: 4-1 only
Megan: 4-1
Weapon R: 4-2-1
On the Yaris motor it honestly makes very little difference. A header in general wakes the car up a little, and sounds great. But we are talking about a very short tube header with this. If it were a long tube design, it would both make more power and benefit more from a 4-2-1 design.
Old 05-09-2012, 09:39 AM   #13
Installation of the header in your driveway is more complicated if you live somewheres where they salt the roads in winter. The 14mm bolt that holds the header to the midpipe was rusted down to just bigger than a 13mm.....had to use vice grips to get it off....but I still did it in the driveway
Old 05-09-2012, 09:40 AM   #14
^ That's nasty, I give props to you guys in that climate. I'm spoiled in SoCal, I know.
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
FS: DC Sports Header + New A/F Sensor Return of the Yarii Items for Sale by private party 33 11-19-2008 09:18 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
