Old 06-02-2010, 12:45 AM   #19
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
Let us know when you get your new goodies.
( Some pics would be nice, too! )
Don't be shy.
Old 06-02-2010, 10:16 AM   #20
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Don't be shy.
Yeah, I'll have to figure out that picture posting thing. You know, this is all your fault!
COOL!
AND YOURS TOO MISTER!!!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 06-02-2010, 10:34 AM   #21
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
You are going to love it! no doubt !
I'm still at work so officially I've been working for more than 26 hours in a row! I took a power nap around 5am, can't wait to get this over and work on my car and spend time with my family, man I only have 4 weeks to get most of upgrade done, Natalia will join us the first week of July!
Cheers!
CLA 250, 4MATIC
Old 06-02-2010, 10:42 AM   #22
Herbicidal
Herbicidal's Avatar
That is just WRONG!!! But you gotta do what you gotta do. I hope you are done on time and can go home and get some much deserved rest.
I'm really looking forward to getting/installing the new stuff, then I can finally relax and enjoy all my cd's, mp3's etc, all over again! It will be like all new music!
Old 06-06-2010, 08:20 PM   #23
Herbicidal
Herbicidal's Avatar
All my new stuff arrived on Thursday!
I stayed up until 1:30am Fri night/Sat morning to install it all! Man, I was wiped out on Saturday. There was no way the 2nd amp was going to fit under the passenger seat too, so I had to mount it under the driver seat. To do that, I had to cut out the bracket for the jack. I'll put the jack in the rear next to the spare tire. Once the bracket was out, the rest was fairly easy if not time consuming. I still need to solidly mount the subwoofer in the box, so I can lay it down without it falling out. I was able to use 4 gauge wire for power and for ground so that is good. I drilled a new hole in the firewall next to the AC drain and ran the power wire through a gromet, then zipped tied it to various out of the way things in the engine compartment then up to a fuse block, then over to the positive terminal on the battery.
All the connections appear to be 'solid' and now I need to 'tune it'. I'm re-reading Alien Mantis's recommendations and comparing against what the instruction manuals say. Their settings are more conservative, if I'm undestanding them correctly. I am just about done! All the 'heavy lifting' is complete, now it's down to a screwdriver to make the adjustments.
Old 06-07-2010, 10:21 AM   #24
derickveliz2
Awesome! keep us post it!
CLA 250, 4MATIC
Old 06-07-2010, 05:32 PM   #25
Herbicidal
Herbicidal's Avatar
I haven't made the time to post up the other pics yet, but here's one of the speaker grill I just ordered to protect the 10" sub from when I put stuff in the trunk. Just a little bling in an otherwise black compartment. Hey, it makes me smile!
Old 06-07-2010, 07:15 PM   #26
Alien Mantis
Secret Agent
Fun looking "tarantula" grill you got there.
( Now get busy and post some pics of your new gear in the ride! )
Old 06-08-2010, 03:28 PM   #27
Herbicidal
Herbicidal's Avatar
Looks like the Tarantula grill arrives today (just ordered yesterday)! Oh yeah!!! My stuff from Sonic is literally overnighted! I love it!
Here you go Alien Mantis:
Finally I have some more pictures! As I mentioned before, the install went pretty smooth, just time consuming to do a ‘clean’ install. I used an air powered cut off wheel to remove the jack bracket under the driver’s seat and the jack does fit snugly in the spare tire compartment. I had to place a piece of 2x4 under each amp to get a level mounting spot because of a funky space between some horizontal body supports. This made it easier to connect up the wiring. I figure this allows the air to flow partially underneath and will help with the overall cooling of the amp. I’m still experimenting with placement of the subwoofer box in the trunk. Laying it flat with the sub pointing to the rear of the car takes up the most room, but standing it up and rotating it 90 degrees gives me the most space in the trunk and puts the weight closer to being over the rear axle. Anyway, I’m still playing with the positioning for sound and space maximization of the sub.
Without further ado:
Eclipse XA1200 mono channel amp.
Alpine Type R 10" sub.
Alpine Type R 10" sub, top view.
Alpine Type R 10" sub, connectors. I used the jumpers to set it up for 2 ohms.
10" vented sub enclosure from Sonic Electronix.
Alpine Type R 10" sub-in-the-box.
Preparing for surgery. That car jack mounting bracket has to go!
Where the bracket for mounting the car jack was, under the drivers seat. Needed to make room for the other amp.
The blue wire is 4 gauge for power to the subwoofer amp. The black tube is the A/C breather that vents to the outside of the firewall.
4 gauge power wires through the firewall passenger foot well red for the speaker amp, blue for the subwoofer amp.
Eclipse mono channel subwoofer amp on the left, Eclipse 4 channel amp for the speakers on the right.
Alpine Type R 10" sub in a box. I'm still trying different locations and positions so the wiring isn't finalized yet.
Old 06-08-2010, 03:53 PM   #28
derickveliz2
Looks nice!
I took out the tubes that vents the rear seats, did you take them out too?
Did you put some Poly Fill inside the sub box?
(o:
CLA 250, 4MATIC
Old 06-08-2010, 05:47 PM   #29
Herbicidal
Herbicidal's Avatar
Looks nice!
(o:
Thanks!
Not sure what you mean about the "tubes"?
No, what would that do?
Old 06-08-2010, 10:40 PM   #30
derickveliz2
Originally Posted by Herbicidal View Post
Thanks!
My car came with some ducts that take hot/cold air under the seats towards the rear seats. Maybe yours came without that feature, I took them off.
Every sub-woofer box requires some kind of buffing material, most common used is Polly Fill, it's all about acoustics (in some cases a MUST) check with your woofers specs/instructions.
D.
CLA 250, 4MATIC
Old 06-08-2010, 10:53 PM   #31
Alien Mantis
Secret Agent
Nice photos!
Good job. I mounted my sub amp exactly like you mounted yours.
I used a small piece of 2x2 to level my amp. The floor under the seat is uneven.
Looks like we ran our wires the same way.
I have had no problems with my setup. The amp has plenty of space around it to breath.
You don't need any polyfil in that subwoofer box. The box is already at the max size for that subwoofer. Those boxes are nice. No need to do anything to them. They are ready to go. You typically use polyfil in a sealed enclosure that is smaller, to trick the woofer into thinking it is in a larger box.
Correct size ported boxes, and larger sealed boxes do not need polyfil.
I'm sure you already know this, but if you fold down one side of your 60/40 rear seat, your bass will sound much better.
I have a hatchback Yaris, so this is not an issue for me.
Here is a couple of pics of my setup:
Old 06-09-2010, 01:05 AM   #32
derickveliz2
It's a learning process, thanks Alien, for sharing the proper information, I learn some thing new every day!
I see you have a Pioneer amp. which one is it?
CLA 250, 4MATIC
Old 06-09-2010, 10:34 AM   #33
Herbicidal
Herbicidal's Avatar
D.
Ahhhh! Nope, no ducts for me! Based upon Alien's info, I'll skip the poly fill.
Nice photos!
Thanks!
Yup, that floor is something else.
Nice pics! Very clean install!
Great minds think alike! Haha! I haven't tried folding the seat down. I usually pick up my kids after school, so they are in the rear seats.
Old 06-09-2010, 06:33 PM   #34
Alien Mantis
Secret Agent
Basically, this one. ( I have the older model )
http://www.sonicelectronix.com/item_...GM-D7500M.html
Old 06-10-2010, 11:54 AM   #35
Herbicidal
Herbicidal's Avatar
OMG!!!
IF you follow these instructions, you will be close, and have a good baseline.
You might be totally happy with it using these settings.
Let me know how it turns out. Good luck.
I finally was able to spend about 2 hours yesterday to tune my amps. Crawling around in the back seat with Alien Mantis's instructions in one hand and a small screwdriver in the other, moving the front seats all the way forward so I could get to the adjustment screws, making adjustments, moving the seats back to the regular positions so I could sit in the drivers seat and listen, then repeat the process all over again about six more times. When I first took a look at the adjustment screws, everything on both amps was basically turned "off". While installing them, I didn't even look at the adjustment screws because I really didn't understand them. Since last Saturday, essentially I have not been using the subwoofer amp, and for another two weeks at least, the speaker amp! I was so focused on the install and keeping it all neat and tidy I just didn't even pay any attention to what position those adjustment screws where in! What a dumba$$!
HOLY FREAK'IN MOTHER OF BASS BATMAN!!!
I can't believe the difference! I still have a HUGE $hit eating grin plastered on my face this morning! AND I'm using the stock head unit! I can't imagine the sound getting better than this, let alone what a decent quality HU would do for me! WOW!!! Obviously I am very happy with the amps, speakers and subwoofer! Once I was done, I even vacuumed and washed my car. Ahhhhhhhh! My 13 year old daughter was in the house and came out to the garage to find out what the heck was going on!
LESSON: Make sure to TUNE YOUR AMP(s)!!! If you haven't done it yet, get out there and do it!!! Othewise you are just wasting your hard earned $$$'s!!!
Old 06-10-2010, 12:01 PM   #36
derickveliz2
CONGRATULATIONS, MISSION ACCOMPLISHED !!!
CLA 250, 4MATIC
Sub and amp for sale TEHxFALLEN V1.2 Items for Sale by private party 34 05-17-2010 09:06 AM
Custom Lift Back Hidden Sealed Woofer Box TinyGiant DIY / Maintenance / Service 42 04-15-2010 03:36 PM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
Custom Sub Enclosure (inc sub, power cap, amp) wado Items for Sale by private party 3 09-18-2006 11:53 AM
