![]() Drives: 2007 Yaris Join Date: Jan 2010
Weird starting issue 2007 auto yaris
About twice a week when I goto start the car it will crank for a while and then start. Like its having a hard time starting. Today it made a sound like it was winding up and then started. These fits usually only last a couple of seconds and its never failed to start. Is this just the way the car is? Thanks
2007 auto yaris 4 door. |
Half a Bubble Off Plumb
In several past discussions of this same issue on this board, it's generally turned out that someone was turning loose of the key too quickly when the starter motor starts turning. Hold it in the Start position a little longer.
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Need more information: mileage, last tune-up, last maintenance, general up keep, idle and performance, and what you have done or tried...etc.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
I'd like to bump this as my wifes Yaris is doing this now.....
she has always turned the key to start and released it immediately, over the past few days the starter engagement has been getting weaker sounding and the turn over is slowing down....I'm wondering what could cause it....I have tried to get her into holding the key until the engine starts, but it still is slow to start with the same conditions. I doubt it's the battery but I'll look into it further |
No one?
Might think about load testing the battery to see if it's on the way out.
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Hot shutdown? Overfilled gas tank in a hot climate? Vapour lock? Bad gasoline? Leaky Injector? I would have the fuel rail tested to see that its maintaining pressure. Check the oil and see if it has a "gasoline" odour. BTW, The car has ECU controlled start and requires the key is held in start position for about 1/2 > 1 second.
![]() ![]() Drives: new vitz Join Date: Apr 2010
Me too have the same problem. When it indicates 'COLD' on the board then it does that. Every morning this happen at the first start. Does anyone have a suggestion?
#9 | |
I think he's saying his car gives balky starts every morning when the engine's cool.
no i mean to say that i have noticed that whenever the car indicate 'COLD', it make a cranking like noise for 5 sec and then starts. its very akward.
I randomly get it on my automatic, it would try to start and it seems longer than usual so i turn the key off to retry again and it starts right up. Usually my yaris starts up in 2 shots thats it, its quick to start. But the delayed starts happened about 3 or 4 times so far i have 66k miles and i do all oil changes and such on my car on my own
a.k.a. "Aothachos"
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
