Old 06-15-2010, 07:05 PM   #19
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
There have been other threads about changing out speedometers. The mileage seems to be stored in there, not in the ECU.
Old 06-15-2010, 08:17 PM   #20
Originally Posted by big lo View Post
Good looking out CT with the link to Ebay that helps alot, I ll be purchasing one next week. But what did you mean about the milage change, I dont think its necessary to do that because you are not changing the computer to the car, but then again I might be wrong, holla at me, with new info if you can.
Like YarisHilton mentioned above, the odometer readings are stored in the cluster, not in the ECM (the car's main computer).
Old 06-15-2010, 08:24 PM   #21
big lo
big lo's Avatar
Drives: 2007 VIOS
Once again good looking to Yaris Hilton & to CT this info has been positive all around, and to rest who commented to this quest for the tach question, thank you. I will buy it anyway and send out the out come, with extra info. Holla at your boy in PR.
Old 06-16-2010, 09:36 PM   #22
b_hickman11
Drives: 08 Sedan
My '07 has a tach and no power package. And every MT sedan I've seen has it.
The MT liftback, on the other hand, doesn't.
My 07 Sedan has no tach and no power package. My 08 Sedan has a tach and the power package. Does your Yaris have cruise control? If it does, is it the OEM cruise or the Rostra Cruise.
Old 06-17-2010, 11:28 AM   #23
Kal-El
Kal-El's Avatar
I assume yours is an automatic? I'm pretty positive that ALL Manual SEDANS have a tach.
And no, I don't have cruise. Factory installed cruise only comes with the power package.
Old 06-17-2010, 02:00 PM   #24
SAV912
Pirate Yaaaaris
SAV912's Avatar
No. Tachs came with S packages or power packages. Sedan or LB.
-SAV
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 06-17-2010, 02:06 PM   #25
Kal-El
Kal-El's Avatar
Anyone have a manual sedan without a tach?
Old 06-19-2010, 11:12 AM   #26
b_hickman11
Drives: 08 Sedan
There were many threads about this back in 2007. A lot of MT folks were on here complaining that their MT didn't have a tach when the automatic's did.
Old 06-19-2010, 11:17 AM   #27
GeneralDon7
Drives: Yaris Sedan
I have the 07 Sedan, but mine was the power package and came with the tach.
GeneralDon7 is offline   Reply With Quote
Old 06-19-2010, 11:54 AM   #28
sickpuppy1
Drives: 2010 Yaris Sedan
2010 sedan w/power package and an automatic and tach. While I dont need it, I like it. Helps me control gas pedal/shift points when I'm in gas saving mode, which is most of the time. And I agree, again while not a necessity for a manual, I wouldnt want one without it and it should be standard for a manual no matter what trim level or package you have. Dumb move on toyota's part. Cutting cost and a way to drive up package sales probably.
Old 06-19-2010, 12:24 PM   #29
Yaris Hilton
Smile
Probably mainly aimed at pushing package sales.
Old 06-22-2010, 04:00 PM   #30
RedHatch08
Canadetroiter
RedHatch08's Avatar
Drives: 2008 3DR 5M
Yeah I have no doubt. Lame.
K&N Air Filter . Rear Debadge
RedHatch08 is offline   Reply With Quote
Old 07-28-2010, 02:38 AM   #31
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
The correct answer is with a MANUAL sedan you only get a tac if you purchase the power package. You also get a dimming dome light, because of this the dealer will state you can't install an OEM alarm, untrue.
I wanted a 5 speed sedan with power package and keyless entry but was told I could NOT have this because of the tac. The dimming dome light tricks the alarm into thinking a door is still open for about 7 seconds.
Reeves360 is offline   Reply With Quote
Old 07-28-2010, 02:38 AM   #32
Reeves360
Old 07-28-2010, 07:06 AM   #33
Kal-El
Kal-El's Avatar
It's not the correct answer. I have a tach and dimmer but NO power package.
However, mine is an "S".
Old 07-28-2010, 08:59 AM   #34
big lo
big lo's Avatar
Drives: 2007 VIOS
Oooo, low blow. I think that going to hurt in morning folks.
Old 07-28-2010, 09:06 AM   #35
big lo
big lo's Avatar
Drives: 2007 VIOS
Old 07-28-2010, 01:13 PM   #36
Carrot Top
Carrot Top's Avatar
Drives: 2008 Copper Orange LE HB
[QUOTE=RedHatch08;480853]
The car has that worthless gimmick Tire Pressure
Monitoring System which is complete and total bullsh!t.
This is SO true!...I had 4 nails in my rear passenger tire and the PSI was 13 and the TPMS did not come on to tell me this, I just happened to gas up and and thought I should check the air in my tires then I realized I must have a nail in my tire, couldn't believe I had 4! Guess, its time to purchase some new tires!
As for the tach, I was told when purchasing my HB (auto) that it comes with a tach as part of the power package.
The YARIS is the REAL Smart car !
Carrot Top is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
I think I was being made fun of for driving a yaris (or my yaris) last night.....hehe PETERPOOP Off-topic / Other Cars / Everything else Discussions 21 05-16-2010 03:19 PM
