#19 |
I found it! I copy the image URL and then did a quick search! it's called:
Universal Coil Spring Control Kit LINK Did you find any problems with this? any noises or concerns? how does affects your suspension? do you recommend it? Thanks
. CLA 250, 4MATIC |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
They're fine for what they cost. They make your ride a little bouncier, as expected when you are adding pressure to the springs. Other than that, they work very well. No noises or concerns, I'd recommend them. (They would suck for racing though, too much bounce.)
The Tanabe springs sit very high in the front compared to the rear, and this is an easy fix. |
#21 |
Thanks
Derick
. CLA 250, 4MATIC |
#22 |
Check it out online with Discount Tires. They have chart replacement for the proper size tire and wheel match up for your Yaris.
#23 |
black shark
Drives: black toyota yaris t3 sprit Join Date: May 2010
hi there, im running 205/40/zr17, and having no problems, but if u going to load people in the back of your car then just roll the rear fenders as the standard springs make the rear fender catch the tires,
#24 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
So 15x7 30+ offset rota rb on 205/50 lowered on df springs won't rub?
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| I NEED A 15" STEEL RIM AND OEM TIRE | robkay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 12-18-2009 11:57 AM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 05:46 PM |
| Need serious Tire and Rim help | thomasward00 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 04-14-2007 02:29 AM |
| Rim sizing - what size to get for OE equivalent? | jay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-20-2006 04:25 PM |
