Old 06-18-2010, 12:06 AM   #217
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I like your idea to build from under the kicks like that,good idea,will come out much easier to attach it all together......keep them pictures coming.
Old 06-18-2010, 02:44 AM   #218
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-19-2010, 06:48 PM   #219
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-19-2010, 09:35 PM   #220
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-21-2010, 05:01 AM   #221
goku87
goku87's Avatar
Drives: Black HB
Ha. I wanted to put some hornblasters in my yaris...
...I'll put them in my taco now lol.
p.s. that's the same fabric I used... i think. you get it from walmart?
goku87 is offline   Reply With Quote
Old 06-21-2010, 11:54 AM   #222
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-21-2010, 02:53 PM   #223
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-21-2010, 08:18 PM   #224
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I'm back.... 2500 miles later.... Saw you got your kicks going... life is sooo much better with midbass.
Old 06-21-2010, 08:36 PM   #225
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-22-2010, 01:37 AM   #226
bzinn 1
bzinn 1's Avatar
Pictures or it didn't happen......lol
Old 06-22-2010, 02:03 AM   #227
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-23-2010, 10:20 PM   #228
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-23-2010, 10:36 PM   #229
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Got the second kick going. I also bolstered the passenger's kick with some Lizard Skin on the inside. I also wired up the 2.9...all I need now is a remote wire relay for the amps...
Pics to come...
you know.... considering you're all sq and show quality and such... why not go with a transistor switch instead of a bosch relay? More reliable than mechanical relays. Just a thought.
Old 06-25-2010, 12:47 AM   #230
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-26-2010, 11:07 PM   #231
bzinn 1
bzinn 1's Avatar
This is looking great......thanks for the pictures of it going in.....it makes it easier to understand how much work is going into it.....lizard skin looks like it would go a long way.
Old 06-28-2010, 02:26 AM   #232
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 06-28-2010, 03:05 AM   #233
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
It's not going to look like this when you're done is it?
Just kidding, looks like quite the project though.
Stove is offline   Reply With Quote
Old 06-28-2010, 02:26 PM   #234
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Anytime. Tomorrow I'll finish the other kickpod up AND seal up the original pod. I'm hearing tighter response from the sealed pod. I'll also mess with some wiring that is causing some panels to flex. I MAY, depending on time, get the sub enclosure working. If not tomorrow, it should be by Saturday. After that enclosure goes in, I'll be taking the long arduous steps of making panels, finishing the pillars and pods, and making the wiring all pretty. That will probably take a month. After that it's seat time. I can't wait to get this thing under the Auto EQ and Auto TA functions. I've got some massive glare in some upper frequencies. It's enough to make you cringe...even as off axis as I have those tweeters. Again, EQing and perhaps a dash mat will help that.
I can't imagine what these L1 Pro SEs would do on axis. I'd say just under the level of horn's abilities to make your ears bleed. There's just NO need for me to play them on axis, they've got GREAT sparkle at 45 degrees.
I've got a busy week. Testing for Yamhill County, interviews...
Good luck with the testing/interview process, I start next Tuesday.
I'm not surprised to hear you decided to go sealed, the tightness offered by sealing a midbass is awesome. I think there really are only two reasons why somebody shouldn't seal up a midbass...
1) The driver can't play the low stuff with much authority and needs the help of an IB enclosure
2) To make a sealed enclosure is just too much work in the given space/install.
You should also gain a bit of efficiency I'd think by going sealed, tho you will also get a slightly quicker rolloff (which doesn't matter cause you have a sub).
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 01:42 AM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 10:48 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 12:47 PM
where can i install these power locks? songa New England 1 12-04-2008 01:41 PM
