Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 07-05-2010, 02:07 PM   #19
syntax
syntax's Avatar
wahahaha ! buti pa si duke aprub na sa senado wahahah
Old 07-05-2010, 03:26 PM   #20
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Originally Posted by jonimac View Post
Tol, SR29 din yata un, TYPE R packaging - LED light
Type-R packaging nga, FYI, mas maliit yung size nung original bulb kesa dun sa nabili ko, although may kasamang mga assorted adapter sizes pero mejo malaki pa rin yung smallest size na nabili ko. I'll try to snap some pics tomorrow para makita niyo yung tinutukoy ko. For the mean time, enjoy the pics muna, heto ine-edit ko na.
rye7jen is offline   Reply With Quote
Old 07-05-2010, 04:20 PM   #21
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@rye, ur right yours was another type, I saw this kind that goes with adapter, all are white. (not sure kung may blue nito).
jonimac is offline   Reply With Quote
Old 07-05-2010, 04:24 PM   #22
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Looks blue dahil sa tints pero White color siya. Madali lang naman ilagay basta meron ka lang flat screw para ma-open yung Dome light cover.
Enjoy the pics.
Old 07-05-2010, 04:32 PM   #23
jonimac
jonimac's Avatar
Astig bro! meron bang pang map light naman? gusto ko sana ganyan kaliwanag.
...linis ng auto mo! bagong ligo?
Old 07-05-2010, 04:33 PM   #24
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@joni, did your blue leds fit perfectly? Mine was a little bit longer so hopefully it will sit right the way it should be.
Old 07-05-2010, 04:36 PM   #25
jonimac
jonimac's Avatar
Yup! It was exactly the same size, just LED sa gitna - 12 yata un maliliit lang.
Old 07-06-2010, 12:56 AM   #26
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Im not sure bro, cguro meron pero alangan pa ako buksan yung map light to check what type of bulb is it. May thread dito kung pano nila tinatanggal yun pero I'm in awe to read the User Manual. Pag sakali makita ko man i-update ko itong thread. Malinis lang tignan yan kasi gabi hehehe!
Old 07-06-2010, 03:29 AM   #27
jonimac
jonimac's Avatar
@rye, madali lang buksan yung map light, I checked it before, pareho sya ng bulb sa license plate. I tried to put blue once, pero di ganun kaliwanag kaya binalik ko sa orig. Try ko rin yung white leds still not enough kaya ang binagsakan nya dun sa park lights sa harap, thats why naging puti yun.
Old 07-06-2010, 04:46 AM   #28
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Ah ok, so libre na ba yung paglagay nung ilaw sa parking lights mo, binili mo lang ba yung mga bulbs?
Old 07-09-2010, 02:46 PM   #29
syntax
syntax's Avatar
@ rye napalitan mo na ung parking lights mo?
Old 07-10-2010, 02:04 AM   #30
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax, hindi pa eh.. Stll figuring out kung pano ilalagay yun and what type of bulb. As of now, may idea na ako kung pano naman palitan yung bulb sa Map light, Wait try ko post ngaun mga pics.
Old 07-10-2010, 02:31 AM   #31
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Sorry for the crappy pics, was taken with an old cellphone.
I've used the flat screw driver which is already included when we purchased the car. Try add some tissue paper or cloth to the tip of the screw driver to avoid scratches.
After yanking both sides (as shown above) you can easily pull the plastic cover.
At this part, gently pull the bulb but be careful not to squeeze them that much.
Sorry this is the best quality i can give.
Old 07-10-2010, 03:20 PM   #32
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
Enjoy the pics.
Attachment 34934
Attachment 34935
Attachment 34936
Attachment 34937
Attachment 34938
Attachment 34939
Attachment 34940
rye, may pic kb nung LED n nilgay m? db yan ung square tpos may maliliit n bulb?
xtremist is offline   Reply With Quote
Old 07-11-2010, 03:09 AM   #33
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@xtrem, Kukuhanan ko pa lang, nakalimutan ko kuhanan ng pics nung kinukuhanan ko ng pics yung Map Lights. Hopefully mamaya. Stay tuned.
Old 07-11-2010, 03:40 AM   #34
jonimac
jonimac's Avatar
something like this rye? palagay ko kasya din dito yung 4x4(16leds), if you want that BRIGHT.
Old 07-11-2010, 04:11 AM   #35
xtremist
xtremist's Avatar
Attachment 35085
ipuplug lang ba yan kapag pinalitan ung lamp o kailangan pa magputol ng wire?
Old 07-11-2010, 06:08 AM   #36
jonimac
jonimac's Avatar
@xtremist, plug n play lang ito bro, see those adapters? yung puti yun yung pasok sa socket ng map light. then connect the leds.
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 01:44 PM
What can I do with a bunch of these LEDs? eTiMaGo In Car Entertainment + Electronics (audio / video / alarm) 14 05-13-2009 04:28 PM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Gauge Cluster LED's Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 11 01-08-2009 12:59 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
