Old 07-08-2010, 05:23 PM   #1
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Yaris front strut install question
I am installing tokico blues on my yaris and have hit a bump. i can't figure out how to get the rubber pieces off the top of the strut tower in the front. Do they just pull off? do I have to unscrew them?
Old 07-08-2010, 05:33 PM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Yep.
Get a blunt edge flat head screw driver and just pry it off.
Old 07-08-2010, 05:37 PM   #3
rningonfumes
I just went out and did it again. (wanted to check on my advice).
...use your finger nail, look at the top pan down to the first ring, go to the second ring and use your finger nail to pick at that second ring. It comes off quite easily. You might be confusing yourself by thinking all of the rubber portion is the cover. Don't let yourself think that the whatever you can see is the whole cover.
ring=ridge.
Old 07-08-2010, 05:43 PM   #4
PHXDEMON
PHXDEMON's Avatar
that was so easy thanks. I was thinking the rubber piece was one piece like you said.
Old 07-08-2010, 05:46 PM   #5
rningonfumes
hehe, you're welcome. I did it last year. Took pictures meant for a write up but haven't gotten to it. I know there is a good one over at microimage you could refer to.
Old 07-08-2010, 05:55 PM   #6
PHXDEMON
PHXDEMON's Avatar
cool now how n the hell am I supposed to get the top strut bolt off?
Old 07-08-2010, 06:01 PM   #7
rningonfumes
Hehe, I knew you were going to ask that!
http://www.sears.com/shc/s/p_10153_1...50000P?prdNo=2 The appropriate size of that would greatly help.
And the appropriate Allen wrench.
Tip:
SPRAY your favorite brand lube/nut loosen thinga ma bob now.
Think smart by positioning the allen key in such a way that it uses the car's metal to hold it in place so that you can use both hands/arms for full leverage to turn the wrench.
Old 07-08-2010, 06:04 PM   #8
bladesmith6
Drives: 2007 yaris HB
6mm allen wrench in the middle, 17mm offset wrench for the nut, hold the allen wrench tightly and loosen the nut with the 17mm socket. should come off pretty easy, the tough part is getting down in there without removing the cowl. If you can't fit the tools, remove the wiper arms and cowl.
bladesmith6 is offline   Reply With Quote
Old 07-08-2010, 07:01 PM   #9
PHXDEMON
PHXDEMON's Avatar
got the offset wrench and got the top part off. Now trying to take the nut the holds the strut mount to the strut off and the center of the strut where the allen key goes completely stripped out. Fuck.
Old 07-08-2010, 07:49 PM   #10
rningonfumes
Um...if you aren't concerned with reusing the stock strut, take a vice grip that will fit and clamp that part that needs the allen key. Again, do it in such a way that uses the car's body to keep it in place.
Assumption of course that there is enough bolt for griping.
Old 07-08-2010, 07:57 PM   #11
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
this is the reason why im not coiled..even wanting to go df210 but its that bolt ....good luck bro..
Old 07-08-2010, 09:46 PM   #12
PHXDEMON
PHXDEMON's Avatar
Did exactly that. Completely ruined the threads but I finally got them on. 270 bucks well spent
Old 07-08-2010, 09:58 PM   #13
rningonfumes
lol...finally!
Old 07-08-2010, 10:11 PM   #14
marcus
toyota
marcus's Avatar
sweet.....
Old 07-08-2010, 11:36 PM   #15
rningonfumes
Pics or it happen!
Old 07-09-2010, 12:28 PM   #16
marcus
toyota
marcus's Avatar
so is it possible to take that bolt on the strut tower with out removing the plastic dash??
Old 07-09-2010, 12:38 PM   #17
PHXDEMON
PHXDEMON's Avatar
Honestly I think it probably would be. I removed the whole cowl though following the factory DIY on how to do it.
Old 07-09-2010, 12:41 PM   #18
Removing the cowl may be a pain, but it is so worth the effort in the end.
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
question about radio install misfits9095 In Car Entertainment + Electronics (audio / video / alarm) 8 06-06-2007 03:08 PM
